Results 1 to 10 of 12
    Apr 2008
    Quote Originally Posted by acenie View Post
    matic sir mag shift sa 3k+++ RPM ok lang ba
    Yes, this is a relatively small displacement gasoline engine, and I would even say it is somewhat to be expected to be reaching 3000rpm to get going at a decent pace. If you prioritize fuel efficiency, try to keep the revs lower, preferably letting it shift at around 2000rpm. But otherwise, driving this way regularly will not negatively affect the engine. That is, after all, only halfway through its entire rev range.
    Sent from my SM-G965N using Tapatalk
    If you ask me, I will shift at 5k rpm (or higher) when I hit the open road. Open up the throttle and try to hit peak power every shift.
    Dec 2014
    Owned one for 5 years. If you accelerate gently, it will shift around 2000 rpm. But the acceleration is really slow. Even if you are gentle, fuel consumption is quite high, around 7 km/l in the city.
    If you want fast, step on the gas harder without releasing until you want to shift up. The car will easily surge forward. As long as you step aggressively, the shift will occur at higher rpm.
4 speed lang ba yung 2009 Altis-V Automatic?
