Page 1 of 2 12 LastLast
Results 1 to 10 of 12
    Jul 2003
    4 speed lang ba yung 2009 Altis-V Automatic?
    Apr 2008
    Quote Originally Posted by acenie View Post
    Yes, hanggang 2014 model 4 speed. Yung sumunod nun CVT na.
    Sent from my SM-G965N using Tapatalk
    Dec 2019
    Quote Originally Posted by GTi View Post
    CVT na yung 2014 models. (11th gen Altis)
    10th gen altis is 4 speed A/T
    Jul 2003
    ganun ba talaga yung shifting high rev hangang 3000RPM tapos mag shift. sa last gear normal lang ba mga speed na mga 90-100 na...
    Altis V 1.6V 2009
    Altis V 1.6V 2009
    Depende sa apak mo yan pero in general since 4 lang gears ma mataas revs bagoi nag shift kasi mas mahaba yung gear ratios nya since konti lang gears...
    Jul 2003
    oo tama depende sa apak pag madiin mataas ang rpm more 3k pa pag shift ... ok lang ba yun
    Apr 2008
    Syempre mas magiging matakaw ang konsumo kumpara sa kung 2k lang pinapaabot mo. Pero hindi naman siya nakakasira. Hanggang 6k pa ang pwede nyang maabutan. [emoji28]
    Jul 2003
    matic sir mag shift sa 3k+++ RPM ok lang ba
    Sa automatics naman, if during acceleration mo talaga ang diin mo sa silinyador/accelarator tinutulak yung engine to go to 3000rpm, then that is how the car will shift.
    Brother has a 1.6G Altis 2009 model A/T, kung controlled ang tapak mo, nagshift naman siya sa around 2000rpm range pero gradual acceleration lang ito (malumanay).
    So, hindi masabi kung may iba bang issue yung sa iyo.
    Iba ba tunug makina? Na parang imbalanced? Kasi nung sa kuya ko, may mali sa tunug ng makina. Turns out, isa sa spark plugs "dead" nung chineck. Nung panahon na iyon, kelangan din mga 2500rpm takbo namin bago talaga mag accelerate yung kotse, di mo makikita mag "Settle" yung rev during coasting sa 1500rpm range kasi kulang sa power na yung makina dahil sa isang "dead cylinder".
    Again, pacheck mo if it really is a concern. Not going to immediately tell you to replace sparks and/or change oil.
    Asa amin pa din ngayon yung Altis, back to "normal" ngayon.
    EDIT: Going to what GTi said, Single VVTi lang itong Altis na carryover sa alam ko from the smaller body/lighter 2001 Altis pa. Later nung nagawa nila Dual VVTi yung Altis generation nito, medyo hindi na ganun kahirap yung makina to accelerate
    Apr 2008
    Yes, this is a relatively small displacement gasoline engine, and I would even say it is somewhat to be expected to be reaching 3000rpm to get going at a decent pace. If you prioritize fuel efficiency, try to keep the revs lower, preferably letting it shift at around 2000rpm. But otherwise, driving this way regularly will not negatively affect the engine. That is, after all, only halfway through its entire rev range.
