Page 1 of 2 12 LastLast
Results 1 to 20 of 33
    Dec 2019
    Toyota drops another teaser of GR Corolla hot hatch -AUTOINDUSTRIYA
    From what we can make out, the GR Corolla will have a more aggressive front end courtesy of a sporty front bumper that's paired with a large intake. Also seen on the camo itself is what looks to be a GR Four decal on the side. It's the name of the all-wheel-drive system that's currently seeing use in the GR Yaris and is also expected to be used in the GR Corolla.
    Aside from the same all-wheel drive system, the souped-up Corolla is also expected to use the same 1.6-liter turbocharged three-cylinder engine dubbed the G16E-GTS in the GR Yaris. Based on Toyota's previous teaser, the GR Corolla could put out 268 PS which is slightly more than what the PH-spec GR Yaris makes; 261 PS. A six-speed manual gearbox will most likely be the sole transmission option.
    Toyota has yet to say when they will the GR Corolla will debut. But since they posted another teaser image, we might not have to wait that long for its official debut.
    Jul 2013
    Toyota GR Corolla Hot Hatch Will Debut March 31 | Car and Driver
    Teaser photos show off the new performance model's GR badge, for Gazoo Racing, its fender vent, and a "GR-Four" badge that suggests it will share its all-wheel-drive system with the rally-inspired GR Yaris.
    Jul 2013
    2023 Toyota GR Corolla Debuts Looking Rally-Ready With 300 HP And AWD | Motor 1
    G16E-GTS 1.6-liter turbocharged three-cylinder engine making 300 horsepower (224 kilowatts) at 6,500 rpm and 273 pound-feet (370 Newton-meters) from 3,000 to 5,500 rpm. The power runs through a six-speed manual gearbox with rev-matching functionality. The GR-Four all-wheel-drive system has selectable 60-40, 50-50, and 30-70 front-rear torque split settings, depending on the driver's preference.
    Magkano kaya to?
    Dec 2019
    imagine this engine and AWD powertrain combo was in the Corolla Altis sedan.
    Jun 2013
    Magkano kaya to?
    If Toyota priced the Yaris GR at php 2.6M since it has 257hp, maybe they'll price the Corolla GR at php 3M since it has 300hp? 😂
    Nov 2017
    GR Corolla, standard release.
    https://youtu.be/s0owby0cwak
    They have the Circuit Edition too.
    https://youtu.be/ciE0uz_A2AY
    Jul 2013
    The Toyota GR Corolla Is Headed To ASEAN | CarGuide
    Thailand is set to launch the GR Corolla as well. The hot hatch is part of Toyota Thailand’s 60th anniversary festivities which will be capped off with a visit from Toyota President Akio Toyoda. Toyoda will be arriving there in December, and will personally launch the GR Corolla reports say.
    may nagparating ng US version GR corolla
    Apr 2012
    And they’re selling for 5.5M hahaha
    Quote Originally Posted by Sweetlucious View Post
    onga grabe
    The problem is the GR Corollas tend to be specced higher from the factory (you won't find a base spec), so most cars are $40k as optioned. Plus US Dealers are marking up the cars because of high demand. I was checking reddit and someone posted one listing the dealer wanted $10k over MSRP so it was $50k na.
    For most luxury imports the rule of thumb was x100 the USD price, then add to that the recent exchange rate and P5.5M doesn't seem too unreasonable.
    But for that price antay na lang ng local allocation sa GR Yaris or Civic Type R.
    Jul 2013
    Jul 2013
    I Bought A GR Corolla - The Hottest Hot Hatch!
    Engineering Explained
    Jul 2013
    Jay Leno Drives the 2024 Toyota GR Corolla — Rally Rocket for the Streets! | Jay Leno's Garage
    Jay Leno's Garage
    GR Corolla Morizo edition engine fails on track, crashes, burns.
    Nate | I’ve studied this video to try to understand what caused it, I still can’t say definitively, but here are the facts of the moment of... | Instagram
    The owner's account:
    My account of the sequence of events:
    This was near the end of session 1 day 2, my first time in group 3, third overall track day, not educated enough to pay close attention to my gauges, not taking cool and hot laps, full send the whole time. Car was hot, oil was thin. Coming around turn 11, oil pressure drops momentarily (as per video), accelerate through 3rd, through 4th, shift into 5th and coast into T14. Engine fails while coasting, unbeknownst to me (you can identify the moment of failure watching the oil pressure gauge), oil spews into the engine bay, onto the track, and onto my rear tires. Downshift input and oil on tires kicks my rear end out to the right sending me off track and into the tire wall. Hot oil ignites engine bay.
    Thomas of The Autopian thinks this was probably caused by too-thin 0W-20 oil recommended by the manufacturer:
    We don’t really know what happened, but let’s look at suspect number one, the possibility that the lubrication on hand wasn’t sufficient for the extra modifications put on the engine. The Toyota GR Corolla normally runs a 0w20 oil, a fine spec for cold flow and efficiency in daily driving, but maybe not the most common race oil (it is what Toyota recommends, though plenty of folks seem to be using a 30-weight for track driving). Let’s look at Pennzoil Ultra Platinum; if we zoom in on kinematic viscosity at 100ºC, or 212ºF, we’ll see that the 0w20 rings in at 8.8 centistokes, while the 5w30 posts up a figure of 10.3 centistokes. Now, 8.8 centistokes is still perfectly safe in many applications, but obviously a stock car is different than one that’s been modified, and oil temperatures in modern cars often climb far beyond 212ºF.
    In this case, the owner of this GR Corolla stated a logged oil temperature of 254ºF, or a hair over 123ºC.
    Jul 2013
    Is the Toyota GR Corolla finally coming to PH? | Autoindustriya
    Recently, Toyota Motor Philippines received regulatory approval to introduce a new passenger vehicle powered by a 1,618cc gasoline engine. In addition, the new approvals listed two versions of the mystery vehicle – one has a reference weight of 1570 – 1585 kg, while the other one has a reference mass of 1590 – 1600 kg.
    Jul 2013
    Jul 2013
    Confirmed: The Toyota GR Corolla is on its way to the Philippines | TopGear PH
    Toyota Gazoo Racing Philippines that made the announcement, to be precise. Toyota has something planned for it on December 17, so keep your eyes peeled.
2023 Toyota GR Corolla Hatchback
