Results 1 to 3 of 3
    Feb 2006
    before gamit ko 18" 235/40 series kaso nagpalit ako kase nagrarub sya sa fender ko..I also esed 2 spacers sa rear and front.. but now nagpalit ako ng 17" 215/50 series para sure kce masyadong malaki ung width ng rubber ko.. pina remove ko din ung 1 leaf spring ko n pina adjust ko ung sa front ko.. pero sa hanggang ngaun nag rarub pa din sya.. my question is may solution pa b para d na mag rub ung rims ko? or do i hav to put back my leaf spring?tanx
    the_worm,
    from what i know, kelangan ng spacers para hindi tumama yung mags/rims, saan yung nagra-rub? sa likod o sa front?
    can you post a picture of your ride?
    Aug 2024
    Quote Originally Posted by "The Worm" View Post
    "Rub issues can often be fixed by restoring the suspension setup, like putting back the leaf spring, or adjusting the wheel offset and tire size further. Double-check alignment and clearance for a safer setup. Good luck!"
problem wid my rims
