Results 1 to 5 of 5
    Jan 2008
    Good day po sa mga 4x4 Fortuner owners. I would like to know whether the rear differential lock is available in the 2016-2017 4x4 fortuner? If yes, is it only available in certain trims or all 4x4 Fortuners? Thanks!
    May 2016
    Quote Originally Posted by taxo_p View Post
    Rear differential lock came with the minor updated 2018 Fortuner. Afaik, late 2017 releases already had it. This was the time they also upgraded the rear drum brakes to discs and added some other features. Just check if it has a diff lock dial to confirm.
    Jul 2013
    Quote Originally Posted by Lakwatsero View Post
    ito din sana reply ko... kung may switch, meron...
    Jan 2008
    So hindi po pala standard yung rear diff lock sa 2017. Nakakita po kasi ako sa 2018 model but not sure if the same is available in the 2016-2017. Salamat po.
    Dec 2019
    AFAIK the pre facelift 2nd gen Fortuners already had rear difflock on 4x4 2.8L V.
    Sent from my SM-N970F using Tsikot Forums mobile app
Rear diff lock available in 2016-2017 4x4 Fortuner?
