Page 1 of 2 12 LastLast
Results 1 to 20 of 42
    Jul 2004
    The news: https://www.topgear.com.ph/news/indu...ef=home_feed_1
    "The affected engines produced by Toyota Industries Corporation (TICO) are the 1GD, the 2GD, and the F33A. Toyota has released a list of the models equipped with these engines, but engine-code nerds would already know how wide the scope of the problem is as far as the carmaker’s model range is concerned. Potentially affected models that are sold locally are the Fortuner, the Hilux, the Innova, the Hiace, and the Land Cruiser 300."
    xxx
    "“Based on the results of the investigation, TICO decided today to temporarily suspend shipments of the affected engines. Toyota has also decided to temporarily suspend shipments of vehicles equipped with the affected engines,” the statement continues. “Going forward, we will provide detailed explanations to the authorities and promptly proceed with appropriate measures, including conducting testing in the presence of witnesses if appropriate.”"
    Jan 2016
    "The affected engines produced by Toyota Industries Corporation (TICO) are the 1GD, the 2GD, and the F33A. Toyota has released a list of the models equipped with these engines, but engine-code nerds would already know how wide the scope of the problem is as far as the carmakerÂ’s model range is concerned. Potentially affected models that are sold locally are the Fortuner, the Hilux, the Innova, the Hiace, and the Land Cruiser 300."
    xxx
    Nothing wrong with the engines naman di ba? It's just the certification, medyo 'dinaya' lang.
    Signature
    i believe so.
    perfectly use-able, but might be an issue for the "documentation-sensitive".
    Dec 2019
    no problems naman mukhang medyo malayo lang sa dieselgate scandal ng VW.
    Swerte ng Toyota and non of those models are sold in the US. Kung mayrun baka another VW dieselgate scandal yan.
    For now, masaya nanaman mga Toyota SA and Managers nyan. Limited arrival ng most sought after toyota cars means, patong to the MAX!!!! hahahah
    Jan 2011
    I'm seeing a pattern here. Even the Daihatsu scandal is on models not sold in the US/EU. It's like Toyota is trying to cut corners in markets where they have the least exposure to being fined in the multi-billion$.
    Quote Originally Posted by cityfolk View Post
    THIS. I guess tsikoteers who refuse to buy made for asia or non US/EU models were right after all?
    One criteria I have for buying a car is that the same model is also sold in its parent country i.e. KDM, JDM, EuDM, USDM.
    Bakit dadayain kung walang problema
    Sent from my SM-S918B using Tsikot Forums mobile app
    Apr 2012
    Quote Originally Posted by valskie01 View Post
    agree...
    Jul 2004
    TMP responds ... https://www.topgear.com.ph/news/indu...e_featured_big
    "“Toyota Industries Corporation, a company affiliated with Toyota Motor Corporation, announced on Jan 29th 2024, that irregularities in horsepower output certification tests applicable to certain countries were found on three Toyota engine models. However, this issue does not affect any vehicle in the Philippines.
    “As a reference, this matter relates to irregularities in the certification process based on national requirements in certain countries, but do not have any impact on horsepower, torque or other powertrain-related values. Additionally, these irregularities do not compromise the emissions or safety of their vehicles.
    “We would like to reassure our customers by stating that we believe their vehicles are unaffected by these irregularities. We apologize for any confusion or concern this issue may have caused.”"
    Jan 2011
    ^That stastement is true but disingenuous. It's true only because the Philippines doesn't have the same high standards. Bottomline is they still cheated. It's time the government raise our standards to at least be at par with the rest of the world so we don't get to be a dumping ground.
    Jul 2013
    This could be the final blow to non-commercial diesel engines.
    Toyota could face penalties for emissions cheating in certain diesel engines | Autoindustriya
    Apr 2005
    The effect now is on those models with diesel engines coming from Japan. Very short to no supply.
    Nov 2019
    Wala bang independent body na nag test for certification?
    Dapat meron at mag fail na dapat yan.
    Pero, iba na usapan if ibang design ng engine yung pina certify pero iba pala yung ginamit for production.
    Jun 2005
    Sabi ang problema lang naman daw ay HP rating dahil sa software.
    Yung innova ko naman 1GD engine. Nung sinalang sa Dyno, sakto naman ang power... 146whp. Kung sa engine dyno that should be around 171 hp. Sakto naman sa nakasulat aa brochure
    Sent from my 2107113SG using Tsikot Forums mobile app
    Nov 2017
    Quote Originally Posted by sirkosero View Post
    They tampered the ECU to make prettier looking graphs according to TG
    Sort of reminds me of some of the daihatsu cheats where they tampered the test report in a way that did not benefit them (e.g swapping the listed chemical used in the fuel tank integrity test)
    I remember seeing dyno charts from Speedlab showing varying power and torque curves from similar Toyota engines.
Toyota Diesel Certification Issue for Engines 1GD, the 2GD, and the F33A
