Bago lang po ako dito at bago lang din akong driver at ang First Car ko is Toyota Vios 1.3 (2nd own)
And I would like to listen to expert to give me some advise kasi ipapa-modify ko ung vios ko.
1.) Manual Window To Power Window Conversion (4 Doors), How much it will cost?
2.) Power Lock Re-Activation (meron na daw tong power lock dati kaso na disable lang so pano sya ma rereactivate or kung papagawa ko mag kano?.)
3.) Mags (already have 15'' inch)
More than 6k inabot yung conversion ng bintana ng innova na ginawa nila mang jorge. Expect a vios to cost the same. Front windows lang po iyon. Reliable naman. Nag power window conversion din father ko sa Datsun 180b niya dati.
Power lock can be seen by a decent electrician. A box of actuators is between 500 to 1000 here in banawe
You can buy surplus window motors and mechanisms intended for the vios...or ask the shop you chose to do it for you.
If you are converting only the front, the guys can place the switch in the two switch blanks between the front seats. A plug goes into the hole vacated by the window winder unless you want ot go through the hassle and expense of replacing the door panels, too.
