Results 1 to 6 of 6
    Jan 2011
    Why is it that my gas warning light turns on even if the guage is still slightly higher than the bottom line, and when refuel about 10 liters, the guage reading almost 1/3 tank full?
    May 2010
    it only tells you that you're about to run low on gas.
    Jan 2009
    What's you car's make and model?
    What's the fuel tank capacity stated on the manual?
    Sep 2010
    Quote Originally Posted by eLai View Post
    ...when it light's,it doesn't mean you're running out of fuel,warning lang yan na minimum na ang gas mo,meron pang laman ang gas tank mo na more or less 10 ltrs. depends on the type of your vehicle,kaya ng magkarga ka ng 10 ltrs. biglang taas ang gauge mo;
    Jan 2011
    before, the warning light signals a when the needle points below the E-mark. Im just wondering why, suddenly, even if the needle is above the E-mark, it lights up. is there a way to clean the sensor? usually full tank from below E-mark is around 35 liters. it's a toyota corolla gli '98 model.
    Jan 2011
    Normal na ang mga piyesa ay humihina ang performance due time and wear, kung gusto u maayos to kailangan palitan and fuel sending unit n nsa loob ng fuel tank.
Gas Warning Light
