Page 1 of 2 12 LastLast
Results 1 to 20 of 28
    Nov 2006
    ask ko lang po sana kung bakit ganun yung sa innova ko bought last april 2012, me irritating noise sya parang bass ang tunog nakukulong sa loob, as in ung buong loob ng car mo nabayo, have it checked sa toyota normal lng daw pano naging normal e nakakairita nga, tapos yung ingay nya mas malakas pag nakataas ung pnaka last row seats sa likod. pg binaba mo yung upuan mejo nwawala pero meron pa rin, nakakairita lang kasi pasok sa tenga ang tunog parang bass bumabayo. anyone experienced it with the new innova? also kinapa ko na rin yung ingay parang nagmmula sa labas pagtataka ko lang bakit papasok sa loob, parang ang tunog nya e matgas, do i have to do or change something?
    please help me po
    You bought a budget-meal minivan (or AUV, whatever...) so don't expect much on NVH. Though I can't really tell if what you're experiencing is normal or not since "noisy" is subjective.
    There are several things that I thought of that could possibly minimize the road noise.
    a) Change your tires to better ones
    b) Upgrade your sound insulation. I believe deadening will work. Just have to clarify on this...
    c) Turn up the volume of your speakers
    Oct 2011
    bass sound sa innova?
    Oct 2011
    *TS,
    Is your Innova a D4-D? Maybe you are referring to the sound of the engine, that is all i can think of sa "bass" sound. If you are inside your car, you could normally hear the engine noise just like a humming sound.
    Nov 2006
    i mean sir ask ko sana kung same ba kmi ng naeexperience ng other innova owners?
    sir un nga naisip ko papadeadening ko sana... ano kaya it will work?
    *retz
    yes boss, bass sound para kang ng sasounds na puro bass lng sa dagundong
    cant reallty say if galing sa makina e kc ung buong loob merong dagundong lalo paglubak at 1k rpm, are you innova owner? naexperience mo rin ba?
    Oct 2011
    Sir, nakapatay ba stereo mo?
    Nov 2006
    yes nakaoff sir
    tahimik ba dapat sa loob? kasi i think hnd naman dapat ganun kaingay e, at pag nakababa nga ung last row nahina san kaya yun
    Oct 2011
    tahimik lang sir. mdyo nagugulugan nga ako doon sa bass sound na sinasabi mo.
    Jul 2012
    ts 'di kaya mababa ang pressure ng gulong mo?
    Nov 2006
    30 po ang tire pressure, ako nga din naguguluhan dun ko lng kasi macompare e parang bass tlga
    kakabili lng dami na agad prob, nung una ung rattle sa me unahan kanan natama daw ung air cleaner sa fender gnawa inangat fender e d ang laki ng awang, pngawa ko lagyan ng insolation foam para mawala rattle aun ok na tapos sa door naman passenger side harap din gnupitan ung parang plastic un daw ung nalagitgit tapos ngaun naman ung bass sounds
    Jun 2012
    Quote Originally Posted by toyapogi View Post
    Masyado po mababa ung 30 psi cold tire (lalo na kapag hot). Karaniwan kapag bago labas sa casa eh nasa 40 someting psi ung gulong. 33 psi is the recomended pressure. Pero ung sa akin 38 psi kasi araw araw ko ginagamit para may allawance saka mas magaan.
    Oct 2009
    pag nasa loob ng motel like victoria or anito..sa loob ng parking nila..
    normal lang yan...
    tested ko na many times :D
    Jul 2011
    ano nga kaya yan? medyo nakakaiirita lang naman sa innova yung engine noise pag hataw sa hi-way.
    suggestion ko sir ikaw yung sumakay sa likod para mas ma-locate mo mabuti kung saan nagmumula. yung half ng rear seats lang para madinig mo talaga. baka yung rear seats mismo baka maluwag mga nuts kasi less annoying sounds pag di naka-hang.
    Oct 2011
    Quote Originally Posted by jaypee10 View Post
    normal lang yan...
    bakit napunta sa motel ang usapan?
    echoes reverberating thru the "tunnel"?
    Jul 2012
    sir try to increase all tire pressure as per owner's manual to 33 psi. then if loaded naman yung innova (full pax load of 7-8), make the rear tires 35 psi. innova 2012 din sa kin sir pero wala naman ako pansin na annoying bass sound.
    Nov 2006
    subukan ko tom sir, un nga pnagtataka ko, hope your suggestion will help, hindi kasi talaga komportable
    Sep 2010
    please help me po
    sir, idea ko lang po, baka po nanggagaling sa mount ng exhaust na tapat sa ilalim ng rear seats. baka po hindi nahigpitan ng mabuti kaya nagvivibrate ang flooring at nagcrecreate ng bass like sound sa loob ng sasakyan. kaya din po siguro humihina kapag nakababa yung third row seats dahil inaaabsorb nito ang vibration. napansin ko po kasi sa innova na gamit ko noon eh umiinit yung flooring sa tapat nung third row seat (certain area lang naman at hindi yung buong flooroing ng upuan) lalo na pag long drive at sa tingin ko po mount ng exhaust yun kaya umiinit din. sana po makatulong.
    First, try testing a similar model and mileage Innova or a brand new unit to see if the noise is the same or not.
    Does the sound accompany the engine revolutions?
    Jan 2012
    Try to check your spare tire. baka hindi mahigpit ang pagkaka ikot kaya umaalog siya. Got out innova last april din at so far wala naman ako na experience anything anoying.
Toyota Innova E 2012 model noise problem
