Thank you to Larshell for lending me his stock springs and shocks. For reference purposes. Here we go:
Rear shock: Suzuki Tokico 1700-81A0 YF3 (gas type)
Extended:
Compressed:
Extended:
Compressed:
Front shock: KaYaBa 1600-81-12 YF26 (fluid type)
Compressed:
Extended:
Front coil spring:
Rear coil spring:
Rear coil spring:
Rear suspension:
Front suspension:
Coil spring spacers sold by GlennSter (less than Php200/ea):
I forgot to check which end of the coil is up, but if you intend to put the spacer on the wider end of the coil spring, you will need Honda Civic spacers. 1993 Lancer spacers work for the narrower end. This is true for both front and rear coils.
The new Monroe shocks have arrived:
Part number front:
Part number rear:
Comparison:
Front Suspension:
Rear Suspension:
[SIZE=5]Hello I am from Venezuela and also I have a Jimny 2002 that I want to raise 2", I want to know which are the corrects numbers of reference of the absorbers Monroe because those that you published are erroneous, they do not appear in catalogue, they are serial numbers, please search in the body of the absorber. Thank you I wait for your response...![/SIZE]
Otep, tama ba yung part number nung monroe?
Sent from my Nexus 7 using Tapatalk 2
doc, i was told by a friend na pwede daw coil springs ng Galant sa 2inch lift ng Jimny?hanap tayo ng surplus diyan hehe
