Results 1 to 10 of 13
April 6th, 2003 09:51 PM #1
Mitsubishi Periodic Service Maintenance Menu:
The Periodic Service Menu serves as your guide for your Mitsubishi vehicle maintenance schedule. It indicates the type of service classification that will be done on your vehicle at certain kilometer readings.
It is highly recommended that you bring your Mitsubishi vehicle to authorized service dealers for a periodic maintenance check up. Mitsubishi vehicle warranty is up to 50,000 kilometers for passenger cars/AUVs and 20,000 kilometers for Light Commercial Vehicles (LCVs). Complying with the regular periodic check up is more economical in the long run as it prevents early breakdown, thereby extending the life of your vehicle.
1000 Km Checkup
A. Operations after engine is warmed up
Change engine oil and oil filter
Check / adjust valve clearance (except for vehicles with auto?lash adjusters)
Check / adjust basic ignition timing (petrol powered vehicles)
Check / adjust basic idling speed and CO concentration (petrol powered vehicles)
Check crankcase ventilation hoses (petrol powered vehicles)
Check cooling system for leaks
Check fuel system clamp for looseness and damages
B. Operations inside the engine compartment
CheckV-belts for cracks, fraying wear and adjust tension
Check condition of distributor contact points
Check condition of distributor spark advancer
Check condition of distributor cap, rotor & condenser
Check ignition cables for damages
Check vacuum pump oil hoses for damages (diesel powered vehicles)
Check condition and clean spark plugs (petrol powered vehicles)
Check air cleaner element for clogging and damages
Check fluid level in automatic transmission (including transfer)
Check engine coolant condition & level
Check brake / clutch fluid & power steering fluid level & condition
Check / adjust brake pedal & clutch pedal for free play
Check / top up battery electrolyte level and terminals for loose connections/corrosion; check battery clamp
C. Operations under the vehicle
Check suspension system for looseness & damages
Check suspension arm ball joints for play & dust covers for damages
Check drive shaft boots for damages
Check steering linkage for damages & loose connections (including seals & boots)
Check gear oil level in manual transmission (including transfer case)
Check gear oil level in front & rear axles
Check exhaust pipe connection / installation for gas leakages or damages
Tighten underchassis bolts / nuts
heck / adjust parking brake stroke & play
D. Operations outside the vehicle
Check brake hoses & pipes for leakages
Check fuel hoses and pipes for leakages
Check tire wear, tread depth, inflation pressure, center cap and tire valve cap
Check windshield wiper nozzle and wiper blade
E. Electrical operations
Check condition and function of all exterior lamps
Check condition and function of all interior lamps
Check instrument panel lamp
Check all instrument panel meters and gauges
Check function of all power windows, power mirrors and power door locks
Check front/rear wipers in all ranges
Check horn
Check warning buzzer
Check power antenna
Light Checkup (5k, 15k, 25k, 35k, 45k, 55k, 65k, etc...)
Check V-belts for cracks, fraying wear and adjust tension
Check intake air & turbocharger oil hoses for damage (vehicles with turbocharger)
Check radiator hoses for damages & proper connection
Check / adjust parking brake stroke & play
Check fuel hoses & pipes for leakages
Check horn
Check power antenna
Regular Checkup (10k, 30k, 50k, 70k, 90k, etc...)
Check/ adjust basic ignition timing (petrol powered vehicles)
Perform emission test
Check / clean condition of throttle body
Check air cleaner elementfor clogging and damages
Check adjust brake pedal & clutch pedal for free play
Check suspension system for damages & looseness
Lubricate suspension arm, steering linkage & propeller shaft with grease fitting
Rotate tires
Check / clean brake pads, shoe linings, discs for wear, brake & drums for wear
Check horn
Check power antenna
APPLICABLE ONLY EVERY 30,000 kms.
Change gear oil in manual transmission (including transfer case)
Change gear oil in front & rear axles
Repack wheel bearings (Check condition and recommend replacement if necessary)
Heavy Checkup (20k, 40k, 60k, 80k, 100k, etc...)
Check basic ignition timing (diesel powered vehicles)
Check/ adjust basic idling speed and CO concentration (petrol powered vehicles)
Check the choke mechanism and linkage
Check gas recirculating system (petrol powered vehicles)
Check body condition for damages (underbody coating & body paint for corrosion damages)
Replace contact point and condenser
Check intake air & turbocharger oil hoses for damages (vehicles with turbocharger)
Check operation of crankcase emission control system (petrol powered vehicles)
Replace spark plugs (petrol powered vehicles)
Inspect condition of fuel injectors
Check/ clean condition of throttle body
Replace air cleaner element
Replace fuel filter
Check/ adjust brake pedal & clutch pedal for free play
Check/ top up battery electrolyte level and terminals for loose connections/corrosion; check battery clamp
Check suspension system for damages & looseness.
Rotate tires
Check front/rearwipers in all ranges
Check horn
Check power antenna
APPLICABLE ONLY EVERY 40,000 kms.
Replace engine coolant
Change automatic transmission fluid (including transfer) and replace automatic transmission internal / external filter
Change brake / clutch fluid & power steering fluid
RECOMMENDED BETWEEN 60,000 kms and 80,000 kms
Replace engine timing belt (Except vehicles with timing chain)
:D
- Dec 2002
- 39
April 6th, 2003 10:21 PM #2to follow or to follow the PMs skeds/instructions show how you care for car.
April 7th, 2003 02:14 PM #3
Ako I follow the PMS sched strictly with our vehicles. Medyo mahal lang nga pero it's preventive maintenance. Di naman kailangang sa casa ito gawin dahil it can be done outside. At least it's a guide for what must be maintained. In the long run doing the PMS prevents high repair costs and time. :D
April 27th, 2008 01:54 AM #4
Hello sir roydok, one of our club member in the strada club posted this 1000 Km PMS, as follows:
The transmission differential fluids were changed at....1000 km!!! Tsk, tsk, tsk. It seems like some money-making scheme is being adopted by a mitsubishi service center. Parang hindi ata tama ito.
Any comments, sir?
BTW, he is based in Baguio City.
- Jun 2009
- 21
July 9th, 2009 04:37 PM #5i own a galant vr6.taga baguio din ako at talagang tumataga ng presyo ang motorplaza jan sir.if u happen to know mitsuparts sa naguilian road dun ka na lang pagawa,datimg mekanik sa mitsubishi ung andun.price is cheaper and service is superb.
June 30th, 2011 11:33 AM #7
i think bro its money-making scheme talaga un motorplaza na yan. at 1k pms pinapaltan agad un transmission at differential oils. engine oil at filter lang ang dapat pinaltan dito.
Grabe naman tong motorplaza!
- Nov 2011
- 36
February 27th, 2012 03:50 AM #8Hello po I'm kinda new here & just got my 1st car about a month ago 1997 Lancer tanung ko lang kung anu ung 555 is breand for shock & bushings?
- May 2017
- 27
July 31st, 2017 06:18 PM #9may mare-recommend po ba kayong shop in binangonan/angono/taytay/cainta/antipolo for PMS. medyo nahal po kasi casa around 9K daw for 35k
- Dec 2017
- 5
December 6th, 2017 09:16 AM #10
I just bought an OEM Honda washer fluid. Ok Lang kaya ihalo sa naka mix na filtered + distilled ...
Windshield Washer Fluids Talk
