Page 1 of 4 1234 LastLast
Results 1 to 20 of 78
    May 2004
    GUYS and GALS,
    I've been searching the tsikot library of forums and ironically, there hasn't been any straightforward topic concentrated on the basics about engines. I know most of us are already aware how engine works but its good to share and educate the uninitiated. I know that most of you might find this irrelevant since you are educated about cars and engines, but not everyone is REALLY aware about how car engines work and other complex mechanisms found on cars. I'm also trying to re-educate myself to update my knowledge about engines as well.
    My source is HOWSTUFFWORKS.COM if you want to read directly from the website.
    May 2004
    HOW CAR ENGINES WORK??
    Have you ever opened the hood of your car and wondered what was going on in there? A car engine can look like a big confusing jumble of metal, tubes and wires to the uninitiated.
    May 2004
    [SIZE=3]The Basics[/SIZE]
    The purpose of a gasoline car engine is to convert gasoline into motion so that your car can move. Currently the easiest way to create motion from gasoline is to burn the gasoline inside an engine. Therefore, a car engine is an internal combustion engine -- combustion takes place internally. Two things to note:
    * There are different kinds of internal combustion engines. Diesel engines are one form and gas turbine engines are another. See also the articles on Hemi engines, rotary engines and two-stroke engines. Each has its own advantages and disadvantages.
    * There is such a thing as an external combustion engine. A steam engine in old-fashioned trains and steam boats is the best example of an external combustion engine. The fuel (coal, wood, oil, whatever) in a steam engine burns outside the engine to create steam, and the steam creates motion inside the engine. Internal combustion is a lot more efficient (takes less fuel per mile) than external combustion, plus an internal combustion engine is a lot smaller than an equivalent external combustion engine. This explains why we don't see any cars from Ford and GM using steam engines.
    Almost all cars today use a reciprocating internal combustion engine because this engine is:
    * Relatively efficient (compared to an external combustion engine)
    * Relatively inexpensive (compared to a gas turbine)
    * Relatively easy to refuel (compared to an electric car)
    These advantages beat any other existing technology for moving a car around.
    May 2004
    [SIZE=3]Combustion Is Key[/SIZE]
    To understand the basic idea behind how a reciprocating internal combustion engine works, it is helpful to have a good mental image of how "internal combustion" works. One good example is an old Revolutionary War cannon. You have probably seen these in movies, where the soldiers load the cannon with gun powder and a cannon ball and light it. That is internal combustion, but it is hard to imagine that having anything to do with engines.
    A more relevant example might be this: Say that you took a big piece of plastic sewer pipe, maybe 3 inches in diameter and 3 feet long, and you put a cap on one end of it. Then say that you sprayed a little WD-40 into the pipe, or put in a tiny drop of gasoline. Then say that you stuffed a potato down the pipe. Like this:
    What is interesting, and the reason we are talking about such a device, is that a potato cannon can launch a potato about 500 feet through the air! There is a huge amount of energy in a tiny drop of gasoline.
    May 2004
    [SIZE=3]INTERNAL COMBUSTION[/SIZE]
    The potato cannon uses the basic principle behind any reciprocating internal combustion engine: If you put a tiny amount of high-energy fuel (like gasoline) in a small, enclosed space and ignite it, an incredible amount of energy is released in the form of expanding gas. You can use that energy to propel a potato 500 feet. In this case, the energy is translated into potato motion. You can also use it for more interesting purposes. For example, if you can create a cycle that allows you to set off explosions like this hundreds of times per minute, and if you can harness that energy in a useful way, what you have is the core of a car engine!
    Almost all cars currently use what is called a four-stroke combustion cycle to convert gasoline into motion. The four-stroke approach is also known as the Otto cycle, in honor of Nikolaus Otto, who invented it in 1867.
    May 2004
    [SIZE=3]The Intake Stroke:[/SIZE]
    On the intake stroke, the intake valve has opened. The piston is moving down, and a mixture of air and vaporized fuel is being pushed by atmospheric pressure into the cylinder through the intake valve port.
    [SIZE=3]The Compression Stroke:[/SIZE]
    After the piston reaches the lower limit of its travel, it begins to move upward. As this happens, the intake valve closes. The exhaust valve is also closed, so the cylinder is sealed. As the piston moves upward, the air/fuel mixture is compressed. On some small high compression engines, by the time the piston reaches the top of its travel, the mixture is compressed to as little as one-tenth its original volume. Thus, the compression of the air/fuel mixture increases the pressure in the cylinder. The compression process also creates the air/fuel mixture to increase in temperature.
    May 2004
    [SIZE=3]The Power Stroke:Power Stroke Image[/SIZE]
    As the piston reaches the top of its travel on the compression stroke, an electric spark is produced at the spark plug. The ignition system delivers a high voltage surge of electricity to the spark plug to create the spark. The spark ignites the air/fuel mixture. The mixture burns rapidly and cylinder pressure increases to as much as (600psi). All of this pressure against the piston forces it down in the cylinder. The power impulse is transmitted down through the piston, through the piston rod (connecting rod), and to the crankshaft. The crankshaft is rotated due to the force.
    [SIZE=3]The Exhaust Stroke:[/SIZE]
    As the piston reaches the bottom of its travel, the exhaust valve opens. Now, as the piston moves up on the exhaust stroke, it forces the burned gases out of the cylinder through the exhaust port. When the piston reaches the top of its travel, the exhaust valve closes, and the intake valve opens. The cycle repeats again with the intake stroke. The four strokes are continuously repeated during the operation of the engine.
    May 2004
    [SIZE=3]Counting cylinders[/SIZE]
    The core of the engine is the cylinder, with the piston moving up and down inside the cylinder. The engine described above has one cylinder. That is typical of most lawn mowers, but most cars have more than one cylinder (four, six and eight cylinders are common). In a multi-cylinder engine, the cylinders usually are arranged in one of three ways: inline, V or flat (also known as horizontally opposed or boxer), as shown in the following figures.
    May 2004
    [SIZE=3]DISPLACEMENT:[/SIZE]
    The combustion chamber is the area where compression and combustion take place. As the piston moves up and down, you can see that the size of the combustion chamber changes. It has some maximum volume as well as a minimum volume. The difference between the maximum and minimum is called the displacement and is measured in liters or CCs (Cubic Centimeters, where 1,000 cubic centimeters equals a liter).
    Here are some examples:
    * A chainsaw might have a 40 cc engine.
    * A motorcycle might have a 500 cc or a 750 cc engine.
    * A sports car might have a 5.0 liter (5,000 cc) engine.
    Most normal car engines fall somewhere between 1.5 liter (1,500 cc) and 4.0 liters (4,000 cc)
    If you have a 4-cylinder engine and each cylinder displaces half a liter, then the entire engine is a "2.0 liter engine." If each cylinder displaces half a liter and there are six cylinders arranged in a V configuration, you have a "3.0 liter V-6."
    Generally, the displacement tells you something about how much power an engine can produce. A cylinder that displaces half a liter can hold twice as much fuel/air mixture as a cylinder that displaces a quarter of a liter, and therefore you would expect about twice as much power from the larger cylinder (if everything else is equal). So a 2.0 liter engine is roughly half as powerful as a 4.0 liter engine.
    You can get more displacement in an engine either by increasing the number of cylinders or by making the combustion chambers of all the cylinders bigger (or both).
    The piston displacement is found by multiplying the area of the piston head (whose diameter is called the bore) by the height of the cylinder (i.e., length of the stroke)
    May 2004
    [SIZE=3]OTHER PARTS OF THE ENGINE:[/SIZE]
    [SIZE=3]
    An internal combustion engine[/SIZE]
    Spark plug
    The spark plug supplies the spark that ignites the air/fuel mixture so that combustion can occur. The spark must happen at just the right moment for things to work properly.
    Valves
    The intake and exhaust valves open at the proper time to let in air and fuel and to let out exhaust. Note that both valves are closed during compression and combustion so that the combustion chamber is sealed.
    Piston
    A piston is a cylindrical piece of metal that moves up and down inside the cylinder.
    Piston rings
    Piston rings provide a sliding seal between the outer edge of the piston and the inner edge of the cylinder. The rings serve two purposes:
    * They prevent the fuel/air mixture and exhaust in the combustion chamber from leaking into the sump during compression and combustion.
    * They keep oil in the sump from leaking into the combustion area, where it would be burned and lost.
    Most cars that "burn oil" and have to have a quart added every 1,000 miles are burning it because the engine is old and the rings no longer seal things properly.
    Connecting rod
    The connecting rod connects the piston to the crankshaft. It can rotate at both ends so that its angle can change as the piston moves and the crankshaft rotates.
    Crank shaft
    The crank shaft turns the piston's up and down motion into circular motion just like a crank on a jack-in-the-box does.
    Sump
    The sump surrounds the crankshaft. It contains some amount of oil, which collects in the bottom of the sump (the oil pan).
    Jun 2016
    madalas kino compare ko muna yung medyo mahal at medyo mura na pyesa.
    pero most of the time binibili ko yung mura.
    pinalitan ko pala dati ang u-joint ng sasakyan ko,
    GMC and brand (pero hindi ang GMC na kilala natin sa USA) walang nakasulat kung saan gawa,
    after 4 months, nabali, na straded pa ako sa gitna ng highway.
    Quote Originally Posted by Ris_Poly View Post
    guangdong machineries corporation??
    proud manufacturers usually have their name somewhere there.. product or packaging.
    for high-stress components, i look for originals or "authorized substitutes".
    Feb 2009
    in the very near future, cars will no longer need internal combustion engines (ICE). the hybrids are here- still needs an ICE, but the plug in vehicle which are fully electric does not have ICE and is battery powered that gets charged from an AC voltage source.
    Jul 2013
    With the current price of crude (USD 50/barrel?)... I don't see pure electric cars reaching 10% of the total cars on the road for the next 10 years...
    May 2011
    May 2004
    [SIZE=3]Valve Trains[/SIZE]
    The valve train consists of the valves and a mechanism that opens and closes them. The opening and closing system is called a camshaft. The camshaft has lobes on it that move the valves up and down.
    Most modern engines have what are called overhead cams. This means that the camshaft is located above the valves. The cams on the shaft activate the valves directly or through a very short linkage. Older engines used a camshaft located in the sump near the crankshaft. Rods linked the cam below to valve lifters above the valves. This approach has more moving parts and also causes more lag between the cam's activation of the valve and the valve's subsequent motion. A timing belt or timing chain links the crankshaft to the camshaft so that the valves are in sync with the pistons. The camshaft is geared to turn at one-half the rate of the crankshaft. Many high-performance engines have four valves per cylinder (two for intake, two for exhaust), and this arrangement requires two camshafts per bank of cylinders, hence the phrase "dual overhead cams."
    May 2004
    [SIZE=3]Ignition System[/SIZE]
    The ignition system produces a high-voltage electrical charge and transmits it to the spark plugs via ignition wires. The charge first flows to a distributor, which you can easily find under the hood of most cars. The distributor has one wire going in the center and four, six, or eight wires (depending on the number of cylinders) coming out of it. These ignition wires send the charge to each spark plug. The engine is timed so that only one cylinder receives a spark from the distributor at a time. This approach provides maximum smoothness.
    May 2004
    [SIZE=3]SPARK PLUGS[/SIZE]
    The spark plug is quite simple in theory: It forces electricity to arc across a gap, just like a bolt of lightning. The electricity must be at a very high voltage in order to travel across the gap and create a good spark. Voltage at the spark plug can be anywhere from 40,000 to 100,000 volts.
    The spark plug must have an insulated passageway for this high voltage to travel down to the electrode, where it can jump the gap and, from there, be conducted into the engine block and grounded. The plug also has to withstand the extreme heat and pressure inside the cylinder, and must be designed so that deposits from fuel additives do not build up on the plug.
    Spark plugs use a ceramic insert to isolate the high voltage at the electrode, ensuring that the spark happens at the tip of the electrode and not anywhere else on the plug; this insert does double-duty by helping to burn off deposits. Ceramic is a fairly poor heat conductor, so the material gets quite hot during operation. This heat helps to burn off deposits from the electrode.
    Some cars require a hot plug. This type of plug is designed with a ceramic insert that has a smaller contact area with the metal part of the plug. This reduces the heat transfer from the ceramic, making it run hotter and thus burn away more deposits. Cold plugs are designed with more contact area, so they run cooler.
    [SIZE=3]Timing[/SIZE]
    The timing of the spark is important, and the timing can either be advanced or retarded depending on conditions.
    The time that the fuel takes to burn is roughly constant. But the speed of the pistons increases as the engine speed increases. This means that the faster the engine goes, the earlier the spark has to occur. This is called spark advance: The faster the engine speed, the more advance is required.
    Other goals, like minimizing emissions, take priority when maximum power is not required. For instance, by retarding the spark timing (moving the spark closer to the top of the compression stroke), maximum cylinder pressures and temperatures can be reduced. Lowering temperatures helps reduce the formation of nitrogen oxides (NOx), which are a regulated pollutant. Retarding the timing may also eliminate knocking; some cars that have knock sensors will do this automatically.
    May 2004
    [SIZE=3]Cooling System[/SIZE]
    The cooling system in most cars consists of the radiator and water pump. Water circulates through passages around the cylinders and then travels through the radiator to cool it off. In a few cars (most notably Volkswagen Beetles), as well as most motorcycles and lawn mowers, the engine is air-cooled instead (You can tell an air-cooled engine by the fins adorning the outside of each cylinder to help dissipate heat.). Air-cooling makes the engine lighter but hotter, generally decreasing engine life and overall performance.
    [SIZE=3]Air Intake System[/SIZE]
    Most cars are normally aspirated, which means that air flows through an air filter and directly into the cylinders. High-performance engines are either turbocharged or supercharged, which means that air coming into the engine is first pressurized (so that more air/fuel mixture can be squeezed into each cylinder) to increase performance. The amount of pressurization is called boost. A turbocharger uses a small turbine attached to the exhaust pipe to spin a compressing turbine in the incoming air stream. A supercharger is attached directly to the engine to spin the compressor.
    May 2004
    [SIZE=3]Starting System[/SIZE]
    The starting system consists of an electric starter motor and a starter solenoid. When you turn the ignition key, the starter motor spins the engine a few revolutions so that the combustion process can start. It takes a powerful motor to spin a cold engine. The starter motor must overcome:
    * All of the internal friction caused by the piston rings
    * The compression pressure of any cylinder(s) that happens to be in the compression stroke
    * The energy needed to open and close valves with the camshaft
    * All of the "other" things directly attached to the engine, like the water pump, oil pump, alternator, etc.
    Because so much energy is needed and because a car uses a 12-volt electrical system, hundreds of amps of electricity must flow into the starter motor. The starter solenoid is essentially a large electronic switch that can handle that much current. When you turn the ignition key, it activates the solenoid to power the motor.
Engine Basics And More!!
