Results 1 to 10 of 10
September 29th, 2006 12:50 PM #1
This is taken from the owner's manual of a 2003 Hyundai Starex. May also be applicable for other Hyundai/Mitsubishi vehicles which use the 4d56 engine inlcluding the Grace/H100, Pajero, Adventure, etc.
September 29th, 2006 12:52 PM #2
Please pardon the small size. I must have used the incorrect scanner set up.
September 29th, 2006 12:58 PM #3
Fast facts
Coolant - 30-60% concentration of ehtelyne glycol based coolant
Brake fluid - DOT3 or DOT4
ATF - Diamond [Mitsubishi] ATF Dexron II or Diamond ATF SP I
Steering wheel free play - should not exceed 30mm or 1.2in
Clutch pedal free play - 6 to 13mm or 0.2 to 0.5in
Brake pedal free play - 3 to 8mm or 0.1 to 0.3in
October 2nd, 2006 12:33 AM #6
very nice sir Otep! thanks.
- Aug 2006
- 2
October 12th, 2006 10:00 AM #7Mga Sir maraming ty po sa mga post nyo, it's really beneficial especially for me just having a ride 2nd hand lang po e ..
- Jan 2008
- 5
February 5th, 2008 03:46 AM #8thank you for the specs sir otep. i have spent 3 days searching the web for these. may i ask if these are also appicable to 99 models of starex?
March 10th, 2008 01:09 PM #10
Sir Otep off topic but would you know if there is existing thread for the maintenance schedule of crosswind xuv a/t model 2002?. I bought my unit 2nd hand with voided warranty and since then being service by auto shop convenient to me. Just want to cross check if the pm advise is really necessary. Thanks.
Couldn't have explained it better myself. This was the point I was making. They (either manually or...
SC (temporarily) stops NCAP
