Results 11 to 20 of 29
    ayae kumagat ng mightybond at epoxy..hay... replacement nlang... mukhang mura lang naman to.. san kaya makakabili nito..
    Sent from my Redmi Note 3 using Tsikot Forums mobile app
    PCV VALVE po ito.. san kaya ako makakuha nito
    Hope you can post some pictures.
    Starmobile Up+
    PCV BA ITO? dko makahanap replacement eh.. sa olympia wala
    may diy kaya dito
    this is called PURGE VALVE pala...
    Feb 2009
    Quote Originally Posted by bibo2463 View Post
    may diy kaya dito
    for abs plastic, bakelite or other plastics other than polyethylene, super glue or mighty bond or krazy glue (all of cyanoacrylate base) will work. just clean the area that needs to be joined with acetone to remove all traces of oil for better adhesion and bonding
    Nov 2015
    Bro, ano update sa unit mo? may vibration pa din ba? Im currently experiencing this issue with my Suzuki Swift 2016 1.2. Ang lakas ng vibration pag nakapatay ang aircon or nakareverse and/or neutral. May vibrations at kalampag sa hood, hindi ko ma-distinguish kung saan area (engine area, et al). Any tips?
    Sep 2014
    Ako din may vibration. Usually pag cold start. Pinakamalakas s'ya while on D and nakabrake. Nawawala after around 5 mins of driving.
    Magpapa-PMS ako end of year. Sana wag ako sabihan na normal lang yun.
    Swift 1.2 2014 here.
    Nov 2014
    Quote Originally Posted by cheks View Post
    Quote Originally Posted by Jepster View Post
    2014 Swift 1.2 Same problem. Casa replaced engine support just last month under warranty. Ngayon okay na, minimal na lang vibration when on idle.
need help..Suzuki Swift Vibration on idle
