Results 1 to 10 of 29
- Sep 2015
- 25
June 28th, 2016 05:41 PM #1mga gurus need your expert opinions.. i recently bought a 2008 swift... ang ganda nya sobra enjoy ako.. may problem lang ako na di naman pansin ng dato owner..ok naman daw sa kanya un vibrations.... malakas vibrations nya when you shift to DRIVE tapos naka idle ka..or pag naka stop ka while on DRIVE..pero pag naka nuetral naman wala vibrations.. ok din yung rpm ko..nasa 800 naman constant... ano kaya possible problems nito pag ganto.. pian change oil ko na engine and tranny and changed plugs and linis MAF sensor.. pero ganun parin... by the way nawawala vibrations pag umaandar ka na...wala din vibrations at high speeds and nuetral..pag reverse konti vibrations lang.. thanks in advance..sana may maka help..
- Sep 2015
- 25
June 28th, 2016 08:59 PM #3buo pa eh.. tumitigas kaya mga un?
Sent from my Redmi Note 3 using Tsikot Forums mobile app
June 29th, 2016 08:49 AM #4
Check engine and transmission supports. At that age, they probably lose their flexibility already. Also replace with original parts, replacement parts do not use good rubbers.
June 29th, 2016 09:23 AM #5
I your MIL ( malfunction indicator light) on? Is it flashing?
Your might have a light misfire that was left undetected by the PCM.
- Sep 2015
- 25
- Sep 2015
- 25
June 29th, 2016 11:22 AM #7i found this sa intake manifold.. naka attach sa vacuum hosrs..may crack sya.. possible kaya to?ano tawag dito?? pde kaya iba brand ilagay ko..wala ko mabili d2 privince eh
- Feb 2016
- 101
June 29th, 2016 11:28 AM #8same prob kaya to nung sakin? may vibration din during idle at pag naka off ang aircon. malakas siya pag nilagay sa reverse and drive. pansin ko din pag in-on ang park light or hazard lights with aircon off pa rin. mine is suzuki swift 1.2
June 29th, 2016 12:11 PM #9
June 29th, 2016 01:04 PM #10
Quick temporary fix dun sa crack is to apply epoxy or RTV silicone... and as stated ni jick inspect and replace the hose as necessary
Sent from my Asus ZenFone 2 using Tapatalk
medyo disappointing itong Sealion 5 No ADAS No 360 camera
Yaris Cross 1.5 S HEV CVT vs BYD Sealion 6 DM-i
