Page 1 of 3 123 LastLast
Results 1 to 10 of 29
    mga gurus need your expert opinions.. i recently bought a 2008 swift... ang ganda nya sobra enjoy ako.. may problem lang ako na di naman pansin ng dato owner..ok naman daw sa kanya un vibrations.... malakas vibrations nya when you shift to DRIVE tapos naka idle ka..or pag naka stop ka while on DRIVE..pero pag naka nuetral naman wala vibrations.. ok din yung rpm ko..nasa 800 naman constant... ano kaya possible problems nito pag ganto.. pian change oil ko na engine and tranny and changed plugs and linis MAF sensor.. pero ganun parin... by the way nawawala vibrations pag umaandar ka na...wala din vibrations at high speeds and nuetral..pag reverse konti vibrations lang.. thanks in advance..sana may maka help..
    try to check the engine supports baka basag na.
    buo pa eh.. tumitigas kaya mga un?
    Sent from my Redmi Note 3 using Tsikot Forums mobile app
    Mar 2004
    Check engine and transmission supports. At that age, they probably lose their flexibility already. Also replace with original parts, replacement parts do not use good rubbers.
    Feb 2009
    I your MIL ( malfunction indicator light) on? Is it flashing?
    Your might have a light misfire that was left undetected by the PCM.
    i found this sa intake manifold.. naka attach sa vacuum hosrs..may crack sya.. possible kaya to?ano tawag dito?? pde kaya iba brand ilagay ko..wala ko mabili d2 privince eh
    Feb 2016
    same prob kaya to nung sakin? may vibration din during idle at pag naka off ang aircon. malakas siya pag nilagay sa reverse and drive. pansin ko din pag in-on ang park light or hazard lights with aircon off pa rin. mine is suzuki swift 1.2
    Feb 2009
    Quote Originally Posted by bibo2463 View Post
    Replace the hose. Do the obvious first. The symptoms for your vacuum leak includes higher than normal combustion temperatures, MIL illumination, exhaust smelling like sulfur, surging at cruising speed.
    Sep 2012
    Quick temporary fix dun sa crack is to apply epoxy or RTV silicone... and as stated ni jick inspect and replace the hose as necessary
    Sent from my Asus ZenFone 2 using Tapatalk
need help..Suzuki Swift Vibration on idle
