Results 1 to 7 of 7
    Apr 2009
    I just inflated my new set (two-weeks old) Thailand-made Dunlop Le Mans LM703 (205/40r17) with 37 psi last night.
    This morning, one tire is under-inflated close to run flat!
    I inflated it back with an air compressor pump and took it to a vulcanising shop but we found no holes.
    Now that worries me more!
    Buti pa sana kung may butas nga at least napa-vulcanise ko na kagad!
    What could be the possible cause of such mentioned under-inflation.
    BTW, I used the tire again to go to work, often checking inflation before I enter Slex.
    Ok naman siya ngayon hindi na siya lumambot, pero it gave me "paranoia" na.
    Ang sama sa loob, eh bagong-bago to kabibili ko lang.
    Should I be worried?
    I believe there is a leak on the bead locks of your tire. Have it remounted at a vulcanizing shop, but let them clean the area of the rim (inner circle) prior to mounting.
    Apr 2009
    Noted paps!
    We'll look into that!
    Thanks
    Apr 2009
    pati na din yung part ng pito na nakacontact sa rim minsan diyan sumisingaw
    and minsan yung pito mismo
    Yup tama sila, ipalinis mo lang yung inner circle and pa-check mo yung pito.
    O.T.: Magkano mo nakuha yang mga goma mo? Lemans LM702 na 205/45/17 naman yung sa akin and malapit na akong magpalit.
    TIA!
Under-inflated low-profile tires, but no holes
