Ano kaya problema when there's a noise coming from the right front-wheel at ~50 kph and above. The noise gets louder with the speed, when travelling straight. Nawawala lang yung noise when the road curves to the left or when speed is below ~50kph. Marami nagsasabi na wheel bearing needs replacement daw. I think tranny is not related because the noise doesn't change even if I shift to neutral at high speed.
Other suspected an oblong tire but I just replaced all my tires and the problem still exist. Ride is '99 Accord.
Thanks for any opinion.
i would've said something about your tires.. but since sa isang side lang..malamang bearing nga yan...
OT: speedy.. may sticker ba yung shop nyo?.. on my way to the office this morning i happen to see an EG civic (pearl white ata kulay) entering the meralco compound with a SPEEDYFIX sticker at the back.. ehehhe. wala lang. naalala ko lang yun handle mo dito sa tsikot.. ehehhe
Thank you sa lahat ng nag-reply.
Indeed the right-front wheel bearing was bad.
The wheel knuckle was brought to a machine shop to take out
the bearing from the hub.
guys! i have the same problem sa likod naman nangagaling ang ingay. It started when i replaced the old tires with thereserve tire na relatively luma na rin. Pero yung noise sound like bearing rin nga problem but i tot it allstarted when i replaced the tire d kaya tire lang yun? how can i find out pa check ko na ba dapat sa Mechanic ko?
