Results 1 to 19 of 19
    Oct 2009
    help mga sirs, un isang bolt ng mags hindi na matangal nabilog na, ang masama pa nito sininsil ng nagvuvulcanize sa petron, anong remedy at saan ko ito dadalin? nagtry na ako sa welding shop papainitan ko sana pero hindi din kaya. first time ko patangal un mags, magpapalit na kasi ako ng tires. thanks.
    Oct 2009
    sorry double post. pa delete nalang. thanks.
    bolt chaser... you might also try attacking it from the other side.
    kayah yan.. kailangan lang ng isang marunong gumawa.
    Bolt o nut? Baka nut, yung iniikot. Yung bolt nakatanim sa axle yun
    Sa machine shop mo ipatanggal. Baka mabasag mags mo sa ibang talyer
    Posted via Tsikot Mobile App
    Quote Originally Posted by Newcomer123 View Post
    may ibang kotse kasi, bolt ang linuluwagan pag tanggal ng gulong.
    let's see what TS has to say.
    mr TS, anong kotse ba yan, VW?
    Feb 2009
    Been doin' this a coupla times by drilling the bolt first with a small bit for a pilot hole. I drill that bolt a bigger bit by sixteenth of an inch until the drill bit is as big as the stud bolt or when the stripped lug nut falls off
    Posted through phlpost.gov.ph
    Picture nga ng problemang yan. Di ko ma imagine bakit namilog eh ang tigas nyan
    Oct 2009
    eto na po pictures. nut lang po talaga ang nakalagay.
    http://tsikot.com/forums/newattachment.php?values[t]=99840&contenttypeid=1&poststarttime=1414294911&po sthash=b2bb7a55ae39713630745a135791ee0c
    Feb 2009
    There are socket wrenches to remove lug nuts like this. One type has a tapered or pipe thread in counter clockwise rotation to engage at the same time it is unscrewing the nut. What is commonly available procedure is a power drill and a set of drill bits. Do not use hammer and chisel, it will have more collateral damage than progress
    try mo ito TS:
    lagyan / sprayan mo ng WD40 'yung nut. let it stand for a couple o' minutes.
    hayaan mong pumasok ng husto doon sa loob ng threads.
    after say about 15mins (preferably longer), get a VISE GRIP TOOL. 'yung LONG NOSE type.
    ipitin mo 'yung nut. make sure na mahigpit ang kapit, baka kasi kumalas/bumitaw
    eh madisgrasya ka pa. SAFETY FIRST.
    maipihit mo lang ng konti 'yan, kahit quater turn lang, maaalis na 'yan.
    tama si sir Newcomer123. ang bolt niyan eh nakatanim sa axle.
    may thread/ipin 'yung bolt (parang gears) na naka- kagat naman sa axle na may thread din.
    kaya pag ni- pihit mo 'yang nut, hindi sumasabay 'yung bolt.
    kung sakaling maalis mo, palitan mo na ng bagong nut/lugs and bolt.
    mura lang naman 'yan sa mga auto shops. good luck.
    Oct 2009
    Naku nasinsil na sir, impossible na magamitan ng socket. Idrill nalang ba un nut para maubos o matangal? Saan ko kaya ito pwede ipagawa? napakalapit ko kila sir speedyfix, matatangal kaya nila ito or sa machineshop? Wala daw drill un machineshop dito sa amin. Pasabog na kasi un tire na nakakabit dyan my hiwa na un bukol. 2 kanto lang ang layo nila sir speedyfix sa akin. Thanks.
    Oct 2009
    wd40 spray babarin mo muna mga 10-15 mins.tapos kuha ka ng sinsil tyagain mong unti unti paikutin gamit ang martilyo at sinsil..
    Oct 2009
    Quote Originally Posted by jaypee10 View Post
    Ganyan na ginawa sir. Hindi talaga maikot.
    it's a nut! (not a bolt).
    mr jick, what do you call that threaded socket? is it locally available? i'd like to get a set..
    Feb 2009
    Called a stripped lug nut extractor
    Oct 2009
    Update ko lang to mga sir, okay na po siya. Tinangal un buong wheel kasama un drum then acetylene sa bolt sa loob ng drum then pinukpok palabas un bolt. Then palit new bolt and nut. Thanks sa mga replies niyo po. Malaking tulong.
    Jul 2011
    just sharing, left handed drill bit
    https://www.youtube.com/watch?v=FYvaPbX1sT4
    Feb 2009
    Feb 2009
bolt
