Results 1 to 15 of 15
    Aug 2003
    any simple tests to determine if the shocks or the springs need replacement? i feel that the rear suspension is a bit soft -- parang malambot sobra at bumibigay without really pressing too hard on it.
    sa talambuhay ko, parang di pa ko nagpapalit ng spring... athough shocks madalas.
    simple test to determine if you already need to change your rear shocks is to press hardly on the rear of the car (you might need to put your whole weight on it). kung matalbog na parang naba-bounce at walang bawi, then your shocks are shot.
    Aug 2003
    medyo luma na kasi ung ride ko sir...17 yo na po, and i think the springs are still stock B)
    Jul 2006
    Bro's, ano magandang brand na shocks (front and back)? Sama mga nag pa-refill ng shocks, ok rin b?
    KYB bro maganda
    Feeling ko shock absorber yan meron kaming almost 20 years old na sasakyan dito hindi naman nagbabago yung tension nung coil spring palagi lang shocks ang pinapalitan "Unless" kung yung coil spring mo is pina-initan or pinutulan maaring pwede dun magkaron ng problema. Ano nga palang sasakyan yan bro?
    Aug 2003
    a very old '89 corolla XL po B) plano ko sana to bring a pair or two of kyb shocks to the talyer. concern ko lang e baka ung springs pala ung kelangang palitan
    Nov 2003
    malamang shocks lang yan.
    malambot talaga coil springs sa likod ng modelong yan.. halata lalo na kung puno ang likod. you can change them with a more stiff aftermarket parts if you want but better check your shocks first.
    check the shocks first. they're the ones that usually give out first.
    Naturally, springs, lumalambot yan dahil lahat ng material na may stress, may fatigue kung tawagin. Lalo na yan ride mo medyo matagal nang ginagamit. Subukan mong maghanap ng surplus na spring kung di makuha sa shock replacement. Yung inaakala mong parehong pareho, corolla din.
    Ngayon, kung medyo nagtitipid ka, tulad ng ginawa ko sa kotse ko dati na 89 model din na singkit, bumili ako ng pads. Medyo nabago lang ng konti ang feel sa rough road.
    Brgds....
    baka nga shocks yan...
    pero for information, you don't need to buy surplus springs if kung talagang springs nga ang sira.
    brand new springs costs around 800-1200 depending on the vehicle. yung father ko, nagpalit ng springs for a corolla 2000 love life model dahil nung nabili nya yung car ng second hand eh putol yung springs. he got the springs for 800 pesos each at minerva alabang.
    Mar 2007
    springs only need replacement pag nag sag na. pero matagal yun saka kung laging mabigat ang load. baka natural na malambot ang design ng likod ng car mo. Kung gusto mo tumigas, changing the shocks will only help a little you need to change the springs.
    san gingawa ung torno shocks? any idea and how..
    May 2005
    if im not mistaken around P500 to P600 lang ang stock spring nyang ganyang modelo sa toyorama, new denso or toyocars.
    pro malamang shocks yang problem mo, happened to me bofore.
    brand new kyb shocks sa rear would cost around P1,600 to 1,800, depends kung saan mo bibilin. I opted for refill sa cruven, P800/shock
shocks or springs?
