Results 1 to 12 of 12
    I took my Nissan Maxima '89 to a local mechanic yesterday for tune-up and oil change. Nung paalis na ko, napansin ko parang maganit yung manibela, hanggang makauwi na ko bahay. Then, I checked the reservoir, may laman na, so nag-top up rin ako. Then try ko ulit galawin yung manibela, same pa rin, maganit pa rin. Then while revving, napansin ko na gumagaan manibela, mas mataas na rev, mas magaan ang manibela.
    I was watching the tune-up and oil change process the whole time, and wala naman ako nakita na may nagalaw or ginalaw bukod sa spark plugs and oil filter during installation.
    Kung may ginawa man sya na iba, is just rev the engine high during intake manifold check
    Any ideas what happened or what's causing it?
    Feb 2009
    Quote Originally Posted by CoolSwitch View Post
    you mentioned you just an oil change, there is a possibility oil spilled on the p/s belt or pulley. gates (biggest manufacturer of belts and hoses) recommend the belts and hoses be replaced every four years regardless how they look like to avoid costly and frustrating car breakdowns
    had the belt replaced, wala pa rin...
    halos hindi mo mailiko unless i-rev ng mataas at the same time para lumambot ang manibela
    magkano kaya PS repair kit for 89 maxima?
    Feb 2009
    is your car equipped with progressive power steering (PPS)? if it is, check the wiring to the electric flow control valve. it might have been dislodged or unplugged. this is on the pressure line between the pps pump and the rack and pinion. if the flow control valve right to the outlet of the pump, check for the free movement of the plunger and if free of metallic debris.
    im not sure what PPS is and if an 89 maxima has one... pero I'll have it checked later
    thanks
  6. #6
    maxima ba.. kung mapapalitan mo ng rack for bluebird yan mas maganda.. napakahirap repairin ng rack ng maxima.. kahit nga kasa nagkakaback job...
    i think pump yang prob mo.. may tulo ba rack mo?
    kung repair kit: go to banawe, either kay yen mktg or young bros.. but i prefer yen.... and i pasok mo sa talyer na magoofer ng back job.. sigurado, maswerte ka kung di yan mag-baback-job.
    jick:
    wala pang ganyang technology ang maxima.
    Quote Originally Posted by alwayz_yummy View Post
    yes may leak sya nung una sa area away from the steering wheel, pero this past few weeks, nasa area na na malapit sa steering wheel... kaya iniisip ko baka barado
    magkano kaya ang expected damage kung palit repair kit? TIA
Power Steering seems to work only on high Rev
