Results 1 to 9 of 9
    natural lang ba na mainit yun disc niya after a short trip(10kms),eh bakit yung isa driver side hindi?i found this out after washing tires and rims,i accidentally touch the disc...the unit is glxi mitsu 2001 mdl.
    Just one stop from moderate speeds can heat up the disc already.
    It's ok so long as it isn't overheating.
    You'd know there's a problem if it starts pulling to one side.
    Quote Originally Posted by max-o View Post
    It is normal for the brakes to get warm to hot in a short drive.
    What is not normal is if there is a big difference between the left & right side. If one side is hotter than the other, the brake calipers might be rubbing or stuck up.
    You'll know this if the car pulls to one side while you drive or when you have applied the brakes to slow down the car.
    Aug 2004
    Oh, and another thing...
    Don't wash the discs while they're hot... wait for them to cool down. It's not a good idea to subject them to such extreme thermal stresses. Hot brake discs should be allowed to cool down slowly.
    +1 on this.
    Na-experience ko na rin yan. Nung na-check ay kinalawang yung isang shafting holding the brake caliper. Linis lang at lubricate yung shafting OK na.
    I pa check mo na lang iyong brake disk na hindi umiinit maaring stuck up iyong piston kaya pag nag brake ka hindi tumutulak . Lilinisin lang iyan.
    I assume na sa unahang mga gulong ito, dahil disc ang sabi mo....
    Hindi normal na mainit ang isa at malamig ang isa....
    Kailangang ipalinis mo ang iyong mga preno, bro.... Mayroon diyang stuck na (ang tingin ko,- iyong umiinit)....
    10.5K:band:
    Quote Originally Posted by rmpmla View Post
    +1 on this.
    this is exactly what the mechanic did. after 1hr + problem solved.
    thanks sa lahat na nag reply.
mainit na brake disk
