considering pareho po silang bagong bili. i know it was a stupid idea pero nangyari na po eh. i need your help on how to arrange them. my ride is boxtype pajero. thanks guys
Whatever you wish to mount in front will always be right because its your ride![]()
It doesn't matter because you will be rotating the tires regularly as part of maintenance.
Just make sure that the tires on each axle are a match. E.g. both front tires are similar, both rear tires are similar.
thanks guys. i was thinking kase of putting the AT tires infront because mabilis mag-wear ang front and since I rarely go offroad
I suggest AT sa front for road grip issue, MT sa rear for off-road traction naman.
You need not rotate, but you will need to buy a pair when it wears off. Make sure ipabalance mo ang mga gulong and maintain the right tire pressure all the time para maganda ang wear and tear nito. Sa front make sure na align and proper ang camber settings.
