Results 1 to 10 of 25
- Apr 2007
- 42
January 10th, 2008 01:37 PM #1rinig po sa mga humps, lubak at pag lumiliko left or right lalo na pag medyo rough roads. sabi sa servitek engine supports daw, posible po ba??? nagbabawas nga rin po pala power steering fluid ko. ano pa kaya possible cause nito??? for corona 95 nga po pala...thanks.
January 10th, 2008 02:16 PM #2
boss try mo muna pa check bushing mo sa shock absorber baka yung goma nya lang pudpod na kaya yung bakal sa shock absorber ang maingay
mura lang po yan kaya pwede mong sugalan ang gastos
- Dec 2007
- 17
January 10th, 2008 09:07 PM #3bro, try mo pa-chek right and left constant velocity joints baka punit na mga boots nya at natuyuan na ng cvj grease, isa yan sa mga cause ng tok-tok sound habang right and left turns ng manibela. hope this helps
January 11th, 2008 12:14 AM #5
+1 sa engine support ganyan din symptoms ko
alternative diyan dalhin sa cruven/zee para sa mga injectibles nila (temporary solution) or kung may budget palit engine support talaga brandnew
power steering mo check mo yung mga tubo or malamang mag repair kit kana
medyo ma edad na tsikot mo kaya lumalabas na sakit tulad ng akin hehe
January 11th, 2008 02:04 AM #6
Nice one.
Hindi motor mount yan may play na ang CV joints mo. Check mo para malaman silungin mo at makikita mo na punit na ang rubber boots nyan.
Tungkol sa steering fluid mo may leak ang hoses niyan o di kaya yong power pump mismo ay sira na. Sundan mo mo yong hose kung saan nagsimula ang leakLast edited by v6dreamer; January 11th, 2008 at 02:39 AM.
January 11th, 2008 04:13 AM #7
January 11th, 2008 05:28 AM #8
hey bro, have your Axles (CV Joints) inspected. possible na nag wear out na ito (mainly due to high mileage and cracks on the CV boot which causes the grease on the bearings to leak out) kaya may naririnig kang knocking sound when you turn left or right.
aite, peace.
January 11th, 2008 09:53 AM #9
rack ends, ball joints, tie rod ends, drag links.. ito mga common na kumakalampag.. pag halimbawa nabibitin ang car mo at nanginginig ang dashboard at makina, engine support ang tama nyan..
January 11th, 2008 09:55 AM #10
pag kumakabig pala, tapos tok tok tok tok tok ang sound, CV joint nga yan..
up for suzuki
Let's keep our Chapter Alive! ATO NI Mindanaoans!
