Results 1 to 4 of 4
- May 2007
- 520
June 8th, 2009 04:05 AM #1hello,
kakapalit ko lang ng gulong pag tanggal ng mags sinilip yung shocks sa harap kelangan daw palitan ng bearing. magkano ba yung bearing? kelangan daw palitan yung dalawa sa harap, P4.5k daw. ganun ba talaga presyo nun? san mura bumili ng bearing?
tapos kelangan daw i adjust yung camber (tama ba spelling ko?) kano ba mag pa adjust? iba pa ba yung wheel allignment sa camber allignment(?)?
sa makati ako so kung sakali sa evangelista ako papa ayos. may marerecomend ba kayo na shop dun na maayos kausap at tapat ang presyo?
salamat sa mga mag reply
June 8th, 2009 05:55 AM #2
eido,
there are two bearings on each side of the front suspension. one is the strut mou t bearing found on top of the shock absorber tower which is visible when you open the hood or bonnet of the engine compartment, and the wheel bearings on the hub. both can affect camber of the front wheel
the strut bearing which is insulated with neoprene or urethane are replaced in pairs since if you only replace one side, will give you handling surprises and might cause slight wandering of vehicle travel. the wheel bearing however, you can replace the side where it is worn out.
jick
- May 2007
- 520
June 8th, 2009 01:25 PM #3*jick.cejoco thanks for the reply
suspension arm bushing pala tawag dun. mag kano price nun?
saka kano din mag pa camber adjust?
thanks
- Sep 2007
- 215
June 12th, 2009 07:06 PM #4
Buy adhesive remover or try the Johnson's baby oil approach. See if it works for you.
Removal of Rain Visor and Chrome Door Handle and...
