Page 1 of 2 12 LastLast
Results 1 to 20 of 35
    Oct 2004
    i had my power steering assembly checked last week, medyo may tunog na iba kapag nag full turn ka. ang findings ng mekaniko, kelangan ng palitan ang pressure hose, that'll cost me P4,500. any suggestions on the price and where i could get a good deal for it?
    Around Php 900 sa ABC hose sa Rizal Ave near R.Papa station. Yun nga lang medyo malayo kung tiga-Tandang Sora ka (like me!). hehehe.
    Jan 2003
    pwede mo palitan hose lang using the old fittings pa rin just make sure you get the same inside diameter of the original hose. thats what i did to my hi-ace before... nung nag pa order kami ng parts sabi ng toyota 12,000 daw yung pinakita namin sample. ginawa nung kumpare kong may autosupply naghanap ng ka size na hose at pina press, ayun 2 years na no problem pa rin
    Saka pwede ka pa mamili ng hose type. I usually upgrade to heavy duty ones with a steel core.
    Oct 2004
    Quote Originally Posted by OTEP
    parekoy, yung hose na sinasabi mo dun ko din makukuha sa ABC hose?
    Yup. Bridgestone ang tatak. Ang ABC ay malapit lang sa bahay ni cousin ferdie kaya siya na din ang nag-install sa Sentra ng friend ko.
    Oct 2004
    parekoy, will i do the same? pagbili ko ng hose sa ABC, hanapin ko bahay ni cousin ferdie mo? teka, san nga ba exact address ni cousin? hehehe..... di nga, dun sa P900.00 di pa kasama yung pag-install?
    Aug 2003
    hmm that's cheap... you buy the hose and have someone else install it?
    i had my PS hose crimped before, but it's leaking again (very slow leak, but noisy PS pump!) there's some sort of fitting from the rubber hose to the metal pipe. is that fitting included in the 900 pesos? or additional cost?
    I suggest hanap ka nalang surplus na maayos, iba padin ang tamang sukat eh. Pero kung magpapagawa ka, dami din dito sa may Santolan/Floodway/Ligaya area.
    dito sa binondo, P450 lang kuha ko tama si otep brigestone ang brand nung hose 4 yrs na ok pa rin....
    Oct 2004
    Quote Originally Posted by shadow
    bro di kaya yung P450.00 na Bridgestone hose na nakuha mo, P900.00 na din ngayon? hehehe.... 4 years din yun!
    Oct 2004
    merong nag-quote sa akin na mechanic that he can get a heavy duty industrial-type hose, fittings, and have it pressed all for P1800 for my old corolla. meron na kasing leak yung orig hose ko. okay na ba yung presyo considering he will be buying the hose, the fittings, and having the fabrication done? i just don't know kung bridgestone quality yung hose, but he said it will even be stronger than the orig hose.
    Aug 2004
    had the PS hose of my old sentra replaced last year sa Servitek.. cost me 1,250 yata, all in na..though experience ko lang ay medyo maingay kapag medyo todo kabig sa manibela like pag nag maniobra ka. but wala naman ingay pag straight driving lang..
    Oct 2004
    Quote Originally Posted by raikonen
    mura yun ha! considering yung magandang hose is around P900, that means yung fittings and labor amount to only P350! kaso, yung ingay nga ang gusto kong i-avoid. does that mean wrong diameter yung PS hose na nagamit? what causes the noise anyway?
    Aug 2004
    Quote Originally Posted by jayelgee
    yap.. 9k kasi orig sa nissan kaya replacement na lang ginamit ko. madalang ko na din kasi gamitin yung car, mga once or twice a month na lang.. 750 yata yung hose (industrial grade), 250 for fittings and crimping and 250 labor. but that was last year pa. kilala ko kasi yung dating supervisor dun kaya di na sila nagpatong dun sa materials.. binigyan ko na lang 50 tip yung gumawa.. he told me na unless orig hose ang gamitin mo, may ingay talaga pag hard turning na.. i think the noise is coming from the pressure inside the hose or pump.. dunno if this is an isolated situation..
    maybe we can ask yung ibang nagpalit ng PS hose (not orig), kung may ingay din ba kayo naririnig pag todo kabig na??
    Oct 2004
    meron kasing nagsabi sa akin before na taga ziebart na umiingay daw talaga pag hindi orig yung ginamit. i don't see why unless hindi same specs yung fabricated hose sa orig (ie., iba yung diameter or yung pressure tolerance ng hose). however, sabi naman nung mechanico that is charging me P1,800 to replace my PS hose now, wala daw ingay at mas matibay pa (industrial grade) yung ikakabit niyang fabricated hose. maniniwala ba ako?
    Aug 2004
    in my case, i was informed first na may noise talaga pag di orig yung hose kaya wala ako reklamo..
    regarding yours, ask ur mechanic if meron syang warranty (leaks and noise)dun sa pagagawa mo.. kung wala, then it's your call..
    Apr 2004
    panong ingay ba?? paki describe...
    Bring the hose to ABC and they will provide the exact diameter and type of hose for the specific purpose. I don't see any problem like noise if you use the exact replacement hose.
    Oct 2004
    Quote Originally Posted by afrasay
    ang problema lang sa ABC, ang layo eh...i wonder kung yung shop sa Pasig that was earlier mentioned by one of the tsikoteers would have hoses similar to ABC's...malapit lang ako sa pasig eh
HELP: where to buy right priced pressure hose 4 power steering
