Results 1 to 6 of 6
October 11th, 2011 11:06 PM #1
may naririnig ako na sumasabay sa front na gulong habang nag ccruise. sinubukan ko siya while driving around 20-30kph para marinig ko talaga. wheel bearing kaya? hindi naman ugong yun naririnig ko kung hindi screeching.at wala din siya pag high speed dahil siguro napapatungan ng tunog ng engine.
October 12th, 2011 08:36 AM #2
October 12th, 2011 10:08 AM #4
the last thing done was replace brake pads? is the noise more like continuous thin metal scraping? there must be a bent component in the process of replacing the pads. sometimes it is the splash shield making contact with the inboard side of the brake rotor. sometimes it is the anti rattle spring. look for signs of metal scraping or fresh rusting
October 12th, 2011 01:23 PM #5
actually, nag palinis ako ng brakes kahapon ..siguro nga may hindi na isoli ng maayos or what. bagong problem lang toh. ang original problem is pag nag bbreak ako ng dahandahan may metal scraping sound din. ang lakas naririnig talaga sa loob ng car. sa driver side ko naririnig hindi namin mahuli. kasi brake rotors ko kapal pa. and yes, thin metal yun tunog pag cruising
October 12th, 2011 07:16 PM #6
dinala ko na siya kanina sa talyer..i forgot kung ano ginawa nung mekaniko..parang may pinihit pihit siya sa may brake caliper. sana hindi na bumalik. usually kasi bumabalik siya after a while. under observation parin. thanks for the tips.
My Ford SYNC just updated itself. Anyone here knows what was updated?
2023 Ford Everest Owners Thread
