Results 1 to 12 of 12
    Mar 2005
    We are heading north by tomorrow. What is the recommended tire pressure (front and rear) for my REVO in order to have smooth, hassle free trip? Thanks a lot
    read the manual.
    Sep 2004
    fully loaded ba?
    Jun 2004
    Usually the tire pressure is indicated along the driver side door siding/pillar. Also within the manual. (The pressure indicated assumes you are using stock tire sizes)
  5. #5
    My friend also has a Revo... He puts 35psi on all four tires.
    Sep 2004
    Quote Originally Posted by ILuvDetailing
    taas naman pressure noon.usually it's only 28-32 psi cold measurements. kasi tataas pa yung psi when you drive due t heat.
  7. #7
    Quote Originally Posted by av8or5
    3 psi lang naman yung diff. and over time may lumalabas din na hangin so it evens out. And heavy load karga nila kaya tinaasan niya yung tire pressure. Yun lang nga your tires might wear out faster than usual. I also put 35 psi on all four tires, ok naman, I also carry some stuff.
    Mar 2005
    Salamat ,sa lahat ng nag response, though nasa manual nga yung preferred psi ng tires.. I just want to know feedbacks from you guys on this, nag ba vary din ang sagot, anyway, i just asked this question to one of my coleague , who owns an SR revo. and he told me.. sa front ang lagay niya ay 28 at sa back nman ay 30.. Pa uwi na ako sa office then we have TOTAL gas station near our offrice bldg. doon ko n lang e pa check prssure ng tyres ko.. Thanks... Have a safe Holy Week for all of us... Happy Easter na rin advance
    bongers... advise lang po... mas advisable na mag check ng tire pressure kapag malamig ang gulong (yung matagal na hindi ginagamit). kasi kapag mainit ang gulong tumataas ng konti ang temperature.
    generally, increase rear tire pressure when you have a full load.
    Aug 2004
    Quote Originally Posted by BongersVX200
    pasted on the Revo's driver's side door - front 30psi, rear 36psi.. tires 195x65x15
    i usually put 32-front & 34-rear... pag fully loaded ay 32 & 36.. kasi pag 30 lang sa front ay mukhang malambot pa..
    Dec 2003
    Quote Originally Posted by raikonen
    same din yung tire pressure ko nung gamit ko pa dati yung revo vx 200j namin..
    Sep 2006
    OT: ano naman po recommended nyo para sa stock 95 corolla XE? salamat po! pesensya na po kung medyo OT.. :D
Recommended Tire pressure of an AUV..
