Results 1 to 8 of 8
    Mar 2003
    i just had my brake pads/shoes replaced sometime last month; also had the drums refaced and the brake cylinder/assembly (back) also replaced since it stuck up. Since then i hear this high pitch noise (parang may buhangin sa loob) at least during the first 30 mins of driving then would eventually go away...brake power is good since bnew. sometimes, you have to step on the brakes really hard and then the sound immediately goes away...can this be considered normal? d naman nagbabawas fluid ko.
    TIA!
    yup sir... normal lang yan. afaik, kapag replacement part yung pinalit mo, ganun talaga.
    Mar 2003
    ok...thanks aceshark, but i've been using replacement brake parts for quite some time and previous ones were not noisy except after running on floods.
    neways...i feel relieved somehow as i don't wanna go back to the shop again...i have been spending my 2 consecutive days off there already! hahaha.
    Dec 2004
    It's perfectly normal. We get that on one of our cars, the particular pad (front right) seems okay and no braking problems whatsoever.
  5. jagxtrm Guest
    suggestion ko mag spray ka muna ng brake cleaner sa disc/drum brakes mo to remove brake dust.
    usually napupulbos agad yng outer lining ng replacement pads ... at 'tong 'dust' sometimes causes high pitch sound.
    ganyan din dati sa hilander ko nung nagpalit ako ng 'replacement' pads, basta pag nag ingay, spray lng ng brake cleaner.
    Mar 2003
    sorry for the stupidity...but you have to open the drum to spray it with the cleaner, right? =)
    Quote Originally Posted by BeetOls
    afaik sir, yung disc breaks lang ang nagcacause ng ingay. ewan ko lang talaga. hintay na lang tyo sa ibang replies.
    Mar 2003
    im pretty sure it's coming from the back...but ill try the brake/parts cleaner spray on the disc as well
squealing brakes
