Results 1 to 10 of 15
December 22nd, 2010 02:36 AM #1
pls help...
na experience niyo na po bang matagal nakahang o nakalift car niyo and after that naging matagatag na ride niyo?
December 22nd, 2010 05:07 AM #2
Okay ito kung laging mabigat ang karga mo pag masyadong mataas matagtag na.
December 22nd, 2010 09:16 AM #3
sir speedunlimited.tingen ko po hindi tayo nag kaintindihan... sinasabi ko po car lifter is yung sa mga shop na pang angat ng car pag may sisilipin sa ilalim or may rerepair ano ba tawag dun?.. pls help po sobrang naging matagtag na po kasi yung V namin after elift/ angat ng matagal ..
December 22nd, 2010 09:28 AM #4
December 22nd, 2010 09:28 AM #5
noong gumamit ng lifter at tinignan ang pangilalim mo ano ang ginawa? meron bang pinalitan ng piyeza?
- Jul 2010
- 165
December 22nd, 2010 09:29 AM #6Yung sa akin hindi naging matagtag. Pero parang lumaki ung finger gap. But eventually bumalik din sa normal na ride height.
I guess you just have to take it for a spin and your cars suspension would eventually settle.
December 22nd, 2010 09:53 AM #7
December 22nd, 2010 09:57 AM #8
December 22nd, 2010 01:13 PM #9
Being on a lifter has no bearing on having a hard suspension afterwards. Cars here at the shop spend weeks hanging on lifters with no effect on suspensions. But as much as possible, have the lifter arms or jack stands contact the lower suspension arms, or leaf springs directly. Sometimes, bushing damage and brake hose stretching occurs with having the suspension hanging. Have the car checked though for the stiffness.
- Dec 2010
- 87
December 22nd, 2010 02:05 PM #10kumporme sa design ng suspension at sa dami at laki ng ikot ng spring. kung mc Pherson Suspension system yan, ( combination ng telescopic damper at coil sping ) check mo tire pressure. o malamang baluktot ang shaft nyan. Kung independent Suspension System naman yan. babalik sa dati ang tension nyan. karaniwan na sa mga independent suspension yon lalu na pag na ka lowered, kalimitan jan nag babago yung position yung coil spring seat kaya tumataas at tumitigas ang bouncing effect nya. check mo tire pressure.
nagapalit ako ng pang-ilalim kahapon so takbo ako magpa- alignment service maybe tomorrow. ...
Wheel Alignment
