Results 1 to 20 of 43
    Jun 2005
    Good day people,
    Sino po ang may alam kung saan makakabili ng TPMS. Ito yung nilalagay sa mga tires at remotely pinadadala ang pressure sa monitor through a transmitter. If I am not mistaken, Mitsu Adventure Super Sport is equipped with this one. Yung iba po kasi idiot sensor lang na naka tap sa ABS kung saan di mo alam which tire ang kulang sa hangin.
    Thanks for the info.
    Sa Ford Libis may naka-display sila. Same din ng sa Mitsu.
    Sorry po, hindi ko nacheck ang price. Ibang items po kasi ang kinuha ko.
    Malamang mahal yun, kasi dealership ang nagbebenta.
    Yung sa Paj FM ko di na accurate iba iba ang reading kahit iisa sukat sa pressure guage sa gas station.
    the first mitsu to carry this was the fieldmasters. anyway, yes, it is inaccurate but it can still help show you if a flat suddenly occurs, based on personal experience. i think winterpine is the one supplying mitsu philippines with this.
    yung sensor for each tire attaches to the end of the air valve that goes into the inside of the rim.
    Aug 2006
    mga sir tanong ko lang po sa mga may TPMS diba po kapag nawawalan ng signal ano po ba puwede gawin kasi po naka ilaw lang at nagiinit puwede po ba bunutin yun o kng ano po puwede gawain
    Dec 2010
    Anybody know anything about the ones in Toyotas? Bagong option lang ata ito, sells for around P12,000.
    Quote Originally Posted by April_Ryan View Post
    For those who had this installed (meaning, it did not come pre-installed when you purchased car), from whom did you source?
    I was opting to have this installed on our eve and found one, brand is Orange and it costs 9k at banawe.
  8. #8
    Do they install or do you have to go to tire shop?
    Jul 2013
    Buhayin ko itong thread na ito
    Does anyone here use 3rd party TPMS - yung available sa Lazada?
    Pansin ko, may 2 choices
    1. yung cover lang - easy to install, kaso di ba ninanakaw?
    2. internal - yung tire valve mismo papalitan - pwede ba i-configure yung valves kapag nag-rotate ka nang gulong?
    Jan 2009
    There's a more updated TPMS thread here: TPMS (Tire Pressure Monitoring System)
    Jun 2005
    Yung #1 may lock yan. Medyo mahirap nakawin.
    Yung #2, kailangan mo ipamount sa tire shop. Nababago din daw balance ng gulong. Nahirapan motech ikabit.
    Gamit ko yung #1. Feedback ng opismate ko #2
    Sent from my MI MAX 2 using Tapatalk
    Jun 2018
    Reminder to lubricate or rotate the lock nut of the sensor from time to time. I removed all 4 on my car and had a hard time removing 2 due to oxidation. The tool provided was useless I had to use a plier and blistered my fingers in the process.
    Jan 2009
    ^ If you top-up your tire pressure every month or so, there's no danger of that happening.
    Baka internal tpms nabili ni bro tony8 kaya nahihirapan siya paganahin.
