Results 1 to 5 of 5
February 12th, 2018 12:19 PM #1
Hi mga Co-Tsikoteers
Magpapa advise lang ako regarding sa brake problem ko.
For the 1st two hours of using the car, ok naman sia, wala kang maririnig, but after that, magstart na magkaroon ng screeching sound sa driver side-front.
Pero pag nakapagpahinga na, ~1hr, ok na ulit.
Tiningnan ko ung brake pad, makapal pa naman and walang scratches ang rotor. Ano kaya possible na reason dito?
TIA!
February 12th, 2018 01:01 PM #2
Please provide the following info:
Production year
Make
Model
Mileage
Last thing relevant thing done prior to the start of the symptoms.
- Jan 2011
- 300
February 12th, 2018 03:18 PM #3Akin po 2k ang mileage ganito rin basta pagkatapos ng carwash kahit hindi naman malayo at matagal ang biyahe at pag hand brake.
February 12th, 2018 06:45 PM #4
bleed the brake. if air bubbles come out then that should solve your problem. air expands when its temperature goes up causing the brake to bind. that is why it returns to normal after you rest it for a while.
February 12th, 2018 06:47 PM #5
Planning to buy a second car. Help me choose. Honda accord has 71k mileage for ₱465,000 Nissan...
honda accord 2014 2.4L vs nissan altima 2015
