Page 1 of 6 12345 ... LastLast
Results 1 to 20 of 133
    Aug 2010
    i want to make sure that the brakes of my car is in tip top condition. How do you maintain the brakes?
    pls post the details here?
    Jun 2006
    I'm no expert but AFAIK best way to maintain your brakes is to change your brake fluid at the proper interval. I think its 40,000 kms or 2 years whichever comes first. Brake fluid absorbs water vapor. I forgot the correct term. I think its hygroscopic or something like that. When it absorbs too much water, it will cause all sorts of nasty things to the brake system as well as loose stopping power. So best replace at the recommended intervals.
    Brake pads are replaced when its too thin. Normally you will hear a squeaking noise when its time to change brake pads.
    May 2005
    How about those brake cleaning services that CASA always peddles ?
    Aug 2010
    Quote Originally Posted by userfriendly View Post
    pareho lang ba ang brake pads ng front wheels and rear?
    any idea kung how much ang cost the brake pads?
    Jun 2007
    Front pads are bigger compared to the rear pads if ever the rear braking systems has a disc brake. For the price, it depends on the brand of the vehicle. At a normal usage, the ratio is 2:1 meaning you change your front pads twice before you change your rear brake pads. Factory setting for our brake system is at 70/30, 70 for the front and 30 for the rear.
    Aug 2010
    Quote Originally Posted by aki0125 View Post
    Thanks for your reply.
    the car is L300FB. though i don't feel or hear something unusual, i thought of changing the brake pads on its next maintenance. any idea of the size/specs/brand i need to buy?
    what do you mean by "Factory setting for our brake system is at 70/30, 70 for the front and 30 for the rear"?
    Jun 2007
    Brake distribution ratio
    Your rear brake for your L300 has a drum brake system. Its best to have it clean every PMS to minimize brake dust built up.
    An oridnary bendix standard brake pads and brake shoe for the rear will do the job
    Aug 2010
    how about the front?
    any idea how much is the cost (per set) of brake pads and brake shoe?
    Jun 2007
    900-1100 for the front brake pads
    600-750 for the rear brake shoe
    Aug 2010
    any feedback on the brands TRW and Sure Brake?
    Feb 2009
    check your owner's manual. or, when you feel something's wrong with your brakes, annual check, when it makes noise, when the stopping power is diminished, when you buy a used car without the maintenance record, after an accident, when your brakes idiot light turns on, when your fuel efficiency drops, when it leads or pulls to one side when stopping or if you are an experienced driver, your gut feeling. it is better to be sure than leaving this concern to luck or prayers
    Oct 2011
    Inquired about brake pads in Recto area. Wala sila Bendix puro taiwan brand na R-Specs ang ni offer sa akin.
    Aug 2010
    i suppose that these prices are for 1 set?
    brand?
    Oct 2011
    1 set na yan for both tyres. *900-1100 I assume na Bendix brand na yan. Ung mga taiwan brand ang range ay 550 more or less.
    Dec 2009
    Brake pads are essential parts ng auto... Dapat hindi tinitipid kung me budget, in my experience ok ang bendix, basta wag yung general CT... Mababa friction nun,
    Yearly bleeding of brakes, complete bleed...
    Maingay yang rspec na yan. Bendix nalang. Or Bosch.
    Oct 2011
    Thanks sir cb, kung wala ako talaga ako mahanap na bendix I'll settle for Bosch na lang. Meron naman cguro si Warren nito. Bukod sa maingay ang RSpec, pag baha daw hindi na gumagana ung brakes maybe hindi kumakapit ung brake pads nakakatakot ito.
    meron sa warren. i asked already before. but better call first to check if they have stock of the model youre looking.
    Oct 2011
    okay, may thanks cb!
    Aug 2010
    meron yan sa warren kung bosch.
    there's this store in recto, between masangkay and benavidez, na meron bendix. malaki yung store at puro headlight naka display sa labas. pasok ka sa loob. they have dispaly of brake pads in different sizes and brands. hindi ko lang alam kung original. better bring sample.
Brake Maintenance
