mga bossing good afternoon po !!!! ano ba recommended nyo na shop when it comes to wheel alignment ??? thank you :D
servitek will do. ok din sa 1st station sa edsa or the one sa banawe... forgot the name of the shop though.
If you dont mind having a non-computerized alignment... JP Wheels in Paranaque or Wheelers Suspension Haus in Banawe.
They're not computerized but their rigs are still very accurate and less vulnerable to misacalibrations IMO.
Plus the alignment charge is much cheaper.![]()
pro wheels sa canley road sa pasig...computerized alignment...
i would suggest isabay mo na lang alignment kapag magpapalit ka na ng gulong or kapag mag-rorotate...useless alignment minsan lalo nakapag sobrang uneven na yung thread ng gulong mo...
i had mine done by zapra motors sa may d. tuazon near quezon ave., i should say i am not satisfied kasi ilang balik na ko and di ko pa rin gusto takbo ng front wheels. camber and aligment ang ginawa nila. (manually)
sorry dude wala eh...madali lang puntahan iyan...canley road is the street palabas ng C5 kapag galing kang pasig...
sa shell - coastal mura lang!
P220 alignment sa 4 wheels, P50/ tire ang balancing.
SHELL Las Pinas tapat ng Perpetual Help Hostpital
computerized 3D wheel allignment. (new tech)
cost me P500
If your in the Banawe area, I highly recommend Motorcraft. I had my alignment re-done there the other day because I wasn't satisfied with my first alignment done by EN-TIRE along Laon-laan street. Look for Eric.
What do you look for in a good wheel alignment shop or service?
How do you know if their service isn't good?
Some things i look for:Originally Posted by ironarch
- the people get to work right away
- they dont throw your tires or the tools around
- the equipment they use is OK (not necessarily computerized)
- They can get the alignment done in one sitting.. no more having to come back repeatedly after a test drive because they cant cure the "kabig"... OR if theres still a problem, they can isolate it right away.
- they tell you if there's a problem with your suspension before alignment and the problem really is there.
- there's warranty on the work.
- the tires do look straight/aligned after the work when visually inspected
- price is reasonable
fyi lang po. nadaan kasi ako sa may ultra so i dropped by pro wheels.
yung alignment nila 1000 daw four wheels, package daw nila yun.
contact number 6713855 or 6713879. 68 danny floro street bagong ilog.
