Bad trip mahal ng gulong tapos magkaron ng ganito. on your own opion mga guys safe pa ba ito? yokohama japan super digger yung tire.1 yr pa lng nagagamit. tnx for your opinions.
Last edited by ids; March 20th, 2008 at 01:41 PM. Reason: txt short cut/ wrong use of word
sir any slash sa side wall for me means changing na... well thats my opinon lang naman.![]()
Add ko lang n data, sidewall 2 ply na polyyester. parang visible na yung 1 ply. my plan is to rotate it to the rear para mas safe. At sana pwede pa ma repair like i vulcanize s loob then lagyan ng silicone coating yung outside wall.
yung yokohama ng lancer ko dati nagkaron ng chip ang 2 tyres. yung tyre na umabot sa ply ang damage e later on sumabog, misis ko pa naman ang nag-drive. buti na lang nasa west avenue sya at mabagal lang ang takbo kaya di naman nadisgrasya. yung hindi abot sa ply ang damage tumagal pa ng 2 years hangang sa pinalitan ko last year. napilitan lang na palitan yun kasi natusok ng malaking screw at di na maganda i-vulcanize.
palit na yan. safety first. remember that the tires are the only thing in contact with the road. I've seen a worn tire blow while the car was stationary and parked. If that can happen, what more if your at speed.
You can put an interior on it and use it as a spare tire. As in spare only, replace as soon as regular tire is patched up.
kanit na hindi sa sidewall, kung umabot na sa ply o kaya exposed na ang ply, eh dapat na palitan na lang siya, mapapasok na kasi ng moisture yung ply ,na siyang magiging sanhi ng pagrupok nito, at maaaring umigay siya at pumutok ang goma.
sir it not advisable to put inner tube to a tubeless type of tire. putting an inner tube will make the tire run hotter and have a tendency to break apart because of the heat.
sir that can be repaired pa, they will sew it up and patch it. dito sa amin sa province may nag rerepair yan 1yr guarantee pa.
sa akin, medyo delikado yan. ma bangketa ka lang, pwedeng mag blow yan.
