Originally Posted by
jick.cejoco
if you need spacers to make your wheel offset less positive, use the one without the stud bolts, just plain spacer. the one with stud bolts makes the hub more prone to breaking, overloads the outer wheel bearings and makes the scrub radius too large causing increased turning resistance. if you use the spacers, just make sure the threads of the lug nuts are all used at least or better if it has at least two threads protruding beyond the lug nuts. it is more advisable to use a larger wheel offset than use spacers as a general rule
