Results 1 to 3 of 3
    Nov 2007
    im using a local paj intercooler....
    mga sir, tanong ko lang bakit naninikit yung brakes ko, pina overhaul ko na yung sa harap nung isang araw, pero ganun padin... tapos kahapon yung likod naman yung naninikit..
    ano kaya gagawin ko?
    anong brake pads po ba magandang pampalit sa oem.. manipis na din po kasi yung sa likod ko
    Feb 2009
    Quote Originally Posted by igixxi View Post
    igixxi,
    what year is your chariot? dragging brakes on aging cars can be caused by:
    1. constricted brake hoses
    2. out of adjustment brake master cylinder push rod
    3. stuck brake caliper piston or sliding pins
    4. misadjusted or stuck parking brake cable
    5. contaminated or moisture laden brake fluid ( remember: brake fluid
    is hydroscopic- or prone to absorb moisture from the air)
    check the obvious first and follow the owner's manual for maintenance schedule and specs
    jick
    Jul 2003
    what was done when the brakes were overhauled? any parts replaced at all?
Naninikit na brakes
