Results 1 to 17 of 17
    Kapag slow moving tapos dadaan ako sa medyo lubak, may naririnig ako kalampag sa front wheels ko. Hindi ko sure kung sa gulong or sa axle mismo. Ano kaya yun? Sa bushings kaya?
    sir shoc marami pwede pangalingan kalampag ng car mo. from ball joints(common) to steering links and ends. better go to a reputable shop where they can diagnose your kalampag.
    Quote Originally Posted by shockwel View Post
    Ganyan din akin ngayon due to a busted front right shocks. Sira na tapos may leak.
    usually suspension yung problem pag ganyan ... and shcoks din ang main problem sa kalampag... ano ba yung car mo ???
    di kaya upper suspension arm assembly iyan? ganyan sa akin dati tumutunog basta nalulubak maski di malalim ang pothole o di kaya basta may konting protrusion sa daan
    try mong pukpukin ang gulong mo pag umingay maluwag ang brake caliper mo.
    May 2007
    happend to me before na, shock mounting pala ang sira.. spent mga 800 for one shock pero surplus lang ata yun not brand new orig.
    Aug 2007
    ball joints and bushing. pa-check mo rin.
    Nov 2003
    kalampags are very hard to find online
    better to go to your mechanic and have him inspect your suspension.
    Just had this experience last month on my pick-up. Sure enough, it was the front left shock that was a bit loose. Quick tightening did the job
    don't worry, pinakamabilis ayusin ang pang ilalim ng mga kotse.....unlike electrical...
    toyota corolla 98 model kotse ko sir banawe.
    if ever shocks nga problema, sana naman hindi kailangan palitan. sana tightening lang kailangan gaya ng kay sir memphis.
    thanks sa mga reply.
    Nov 2003
    normally suspension parts only become loose when they are old and need replacing... assuming wala ka pinapalit dun recently.
    Jun 2008
    mga bro i have the same problem ... where can i take my car to be checked
    by a reliable mechanic na hindi taga .... tnx!
    Feb 2004
    Kay JP Wheels ko dinadala sasakyan ko pag pang ilalim ang problema. Yung 2001 Altis ko nga ngayon ay may unusual sound din sa front wheel at low speed especially sa humps.
    san kaya sa pampanga mga reputable shops na marunong sa under chassis? i have this problem also.
    kalampag din ang problema ko sa corolla 97 (bigbody). usually paglumiliko ako pakaliwa. pinapalitan ko na yng tie rod at rack end. mga 1 month mdyo nawala pero bumalik ulit.
Kalampag sa front wheels
