Results 1 to 11 of 11
    Mga bossing;
    Wat do u think about shock refilling?
    Ok ba to?
    Saan kaya meron nito? How much kaya?
    Thanks.
    I haven't tried that and I will never try that.
    I'd rather buy "brand-new" shocks, kahit na sabihin pa nila na reliable/accurate whatever, still I will never try that.
    IMHO kung totoo man na pwede i-refill ang shocks, and if you look at the structure of the shock absorber, compromised na ang integrity niyan once binuksan ang shock absorber and that's dangerous.
    IMHO lang po.
    Not good, sinubukan ko na twice. Tigas ng ulo ko di pa kasi nadala ng minsan. Tumagal naman sya ng isang linggo bago tumagas ulit.
    Kung pinambili ko na lang ng KYB, may reserba pa sana ako.
    Pero kung gusto mo talaga subukan, maraming tumitirada nyan sa Banawe, malapit sa isang tire shop E. Rodriguez side. Karaniwan bebentahan ka nila ng 2nd hand springs para daw tama sa lambot ng gawa nila.
    Feb 2004
    not actually dangerous... kelangan mo lang talaga ng trusted shop for that and also hingi ka na lang ng warantty like for example ilang bwan tatagal para atleast pwede mo pa ibalik kung sa ilang araw lang may problema na kaagad
    Feb 2004
    the savings are not worth the trouble. get KYBs.
    Nov 2003
    kyb or tokiko ka nalang. at least dun sure ka tatagal sya in terms of years and not months.
    Jun 2004
    if your using a corolla 89-90 you can refill the front shock with power strearing fluid. dont use ATF. and it has worked. my corolla has ran 200T+ km and im still using the original front shock. but if your shock are the sealed type. don't bother. you can check out zafra motors in bautista street in makati. thats were i had mine done.
    Jan 2003
    get brand new KYBs. it WILL DEFINITELY give you a peace of mind, imho.
    Boss Mintoy;
    Pwede ba sa Civic yung refill.
    Check lang po.
    Thanks
    shock absorber refill is not advisable if the leaks was evident,
    by the time na maubos uli yung ni-refill na fluid balik uli sa
    dating status shock mo. usually it takes only days to a week
    sira na ulit shocks mo.
Shock Problem... Alternative
