hi! i was wondering if someone would be able to help me...
i own a chery qq.. and yung orig na tire niya is 165/65/13, and pag nagpapahangin ako, i simply do 30psi... kc ito yata ung nakasanayan ng madaming tao, and pag pumupunta ako ng gas station, laging 30 ung default...
last week, i decided to upgrade to bigger tires. i was able to buy 185/60/13 ... and still, i use 30psi for the air pressure..
recently a read an article regarding taking into consideration the "recommended" tire pressure as stated on the tire's sidewall, and mine read 35psi...
my question is, what should i follow.., taking into consideration, that i only have a small car, and my new tires can definitely "easily" support its weight...
should i still stick to jsut 30psi, or should i follow what i just read and increase it to 35? and if im going out of town, lets say im going to baguio..., should i use 35psi? and also, regarding the chery qq, its suspension is not that good, so basically matagtag sa humps and sa normal driving conditions.., im worrying that if i do 35 psi, maciado siya matigas...
hope u guys can give ur opinions.. thanx so much!![]()
