Results 1 to 5 of 5
    Nov 2007
    may alam po ba kayong shops na maayos gumawa nito in the said areas? mga magkano kaya?
    tia
    Jan 2008
    servitek sa alabang tapat ng toyota alabang ok din dyan pero per adjust kasi ang labor nila alignment toe adjust, camber, and caster.. ang basic alignment toe adjust is 300 pesos (di ko lang alam bka tumaas na) yung camber and caster ang mahal.. also choose yung machine na 3D alignment na... wag ka dun sa laser alignment mas accurate yung 3D alignment
    pwede din sa shell las pinas tapat ng Perpetual help hospital ok din dito magaling yung tech nila.. medyo mahal lang at 600 pesos (di ko din alam baka tumaas na) pero kasama na lahat toe, camber, caster adjust..
    for camber and alignment, i only go to two places here in las pinas/alabang areas:
    Servitek (in front of Toyota) and Minerva Tire (Filinvest).
    Jul 2003
    I always have my rides wheels aligned at Shell Customer Cradle located in front of Perpetual Help Hospital in Las Pinas.
    Nov 2007
    salamat mga bossing! any feed back on camber or wheel alignment services ng shell stations?
camber/wheel alignment (alabang, las pinas, zapote area)
