Pipol,
Meron po ba sa inyo ang may idea kung magkano aabot ang magpaconvert ng sentra 89 from manual steering to power steering? Ano shop po ang marerekomenda nyo. Gagamitin po kasi ni misis at sure ako na hindi niya kakayanin ang pawis steering![]()
Pipol,
for a sentra just look for a ps rack, pump and reservoir from a model na compatible. normally around 15-20k yung aabutin nyan...
Sir SPEEDYFIX,
How about for Corolla XL5, is it the same price range? Do you think hindi naman hihina ang engine response/performance if 1.3 engine?
Thanks!!
igorbaby
shouldn't be far off... pero estimate lang naman yan. power will suffer slightly since there is more parasitic drag because the engine has to turn the PS pump pa.
igorbaby,
di ba merun toyota XE na 1.3....ang alam ko power steering yun...
I had my corolla Gl converted from manual to power steering.
power steering kit- 3500
pump------------- 1500
pressurized hose-- 1500
belt-------------- 280
power steering cover-1200
ps oil---------------100
labor --------------2500
carlos,
saan mo pinagawa yung sa iyo? surplus ba yung ginamit? bago ba yung kit mo?
surplus lang pero wala na ako pinalitan, just bolted on, bumili lang din ako ng pump and pressurizewd hose kasama fittings. Yung takip naman, sa states ko pa inorder sa barkada ko, hirap maghanap dito nun. kung meron man, mahal masyado. Casa is 3200 pesos, takip lang. pag wala kasi nun, mainit sa paanan kahit naka aircon ka.Originally Posted by jimaroquai
Dito lang sa personal mechanic ko pinagawa. PM mo na lang ako kung gusto mo magpakabit.
sir how about sa lancer el 93 model, magkano estimate dun?
plano ko din sana ipa convert e. tnx.
most likely same lang ang amount na gagastusin mo. depende kasi sa power steering kit na mabibili mo. Yung sa akin kasi bargain ko lang nabili kasi kaibigan ko. From what i know, kasi nagtanong na rin ako sa banawe, mga nasa 9-10 thousand, di pa kasama pump and hoses and in addition yung pulley to drive the pump
Hi Guys,
Im planning on buying a small body corolla. Issue is di sya power steering. Can you recommend me any good stores to canvass power steering or shop na pwede ipagawa?
Thank you.
Newbie here. Ngaun lang ulit nakapost
Hi Guys,
Thank you.
