Results 1 to 12 of 12
    Jan 2003
    how many times can you have the brake rotor refaced?
    Ideally I wouldnt go over once... and i would only resurface it if i see the rotors are still thick (meaning it needs resurfacing only because it has some slight abrasions).
    Make sure it's not warped either. It may be better to get a replacement rotor then to resurface the old OEM ones.
    may naka engrave sa rotor na minimum thickness..below the minimum palit ka na ng rotors.
    tama si SunTzu, me nakaengrave sa may middle part nung disk sa loob. had mine refaced yesterday lang and ang nakalagay ata is 20mm.
    Dec 2004
    usually meron marking sa rotor ung minimum allowable thickness na pwedeng re-surface sya.
    Aug 2003
    san puwede mag pa reface at how much?
    Mar 2003
    Servitek and the likes offer that service for around P350-400 per rotor...had mine refaced at my suking Yokohama service station.
    standard rate ba yung 400? medyo warped na rotors ko sa harap eh, have to have them refaced.
    Jun 2004
    Quote Originally Posted by ssaloon
    bro. subukan mo bandang San Juan. P250 lang. yun kasi madalas ang ginagawa nila. yung ibang shop sa kanila din nagpapagawa. eto yung address:
    Tonton's Machine Shop. N. Domingo St. San Juan. malapit pagliko ng Pinaglabanan. maayos gawa nila. Hanapin mo si Nards. hope this helps.
    Mar 2005
    Quote Originally Posted by e36speeder
    Tanong ko lang yung brake rotor ba na sinasabi mo ay yung mismong Disc na ini-ipit ng dalawang caliper pads? Kung yun, puede matanong kung mag-warp uli ang brake rotor pagkatapos ng resurface, kung malipis pa sa specs.?
    Nov 2003
    your mechanic or machine shop should be able to tell you kung pwede pa or hindi na.
    Apr 2005
    yep, may minimum thickness na nakaspecify, kung pwede ipa re-face? depende sa condition ng disc. kung may malalim na grooves baka masyado na makapal aalisin para maging smooth ulit, also, better check the break pads. baka may problema na pads kaya uneven kain nya??
brake rotor refacing
