Results 1 to 6 of 6
    asking for some quick suggestion po regarding coilovers..ano po pros and cons? yung friend ko kasi balak ilower at palitan ng mags yung auto nya (evo 10)..whats the best option na pwede..tia
    coilovers.
    PRO: adjustable height
    CONS: very harsh ride... harsher than lowering springs.
    Quote Originally Posted by bigdaddy007 View Post
    pro: you can choose how much to lower the ride height and even adjust the corner weighting of the car.
    con: ride quality will be stiff, uncomfortably stiff. You will feel every single crack and pebble on the road. Long drives will be very tiring.
    Best option: lowering springs (for street use) designed for evo10.
    It'll all depend on the intended use of the coil-overs. While some coil-overs give you an almost unlimited level of adjustability, no amount of shock absorber tweaking will fully make up for a spring that's too hard for road use.
    But seeing as the EVO X already has a pretty rigid set of springs, he could instead go for adjustable shock absorbers... (TEIN with the electronic controller...) and then if he doesn't like the performance, upgrade to coil-overs and sell the shocks... but he should be satisfied with it, unless he drives on the race-track all the time.
    pro:coilovers are(majority) for race track use, adjustable height.
    cons: very pricey and worthless in comfortableness. stiff. worthless because evoX do have a great stock suspension set. maybe save more pepera pera for other upgrades.
    alternatives: aftermarket springs (racing/street may do) and adjustable shocks(gas) or fluid( as i heard, more comfortable ride than gas types, if there are an adjustable fluid shocks)
    goodluck sa project
    *all
    ahh ok..thanks for the reply..
quick question regarding coilovers..
