Results 1 to 18 of 18
    Jul 2006
    Good day guys...
    ask ko lang sa steeering ko.
    kapag stationary kasi ako then iikot ko yung manibela either to left or right
    merong "rrrrrrrrrrrrrrrrruuuuuuuuugggggggggggg....... " sound akong naririnig.
    tapos medyo mahirap ikutin.
    pero wala naman leak yung steering hose ko.
    at saka umaandar naman yung steering pump. medyo mahirap talagang
    ikutin eh.
    anu kaya problema nito?
    meron po ba kayo estimates kung magkano aabutin sa pagpapaayos ko?
    '97 AE101 big body...
    thank you po :D
    Sep 2005
    Try changing the fluid if the problem exists the culprit might be the power steering pump.
    Quote Originally Posted by sirmykel View Post
    Good day guys...
    ikutin eh.
    thank you po :D
    Sir punta ka lang Banawe pacheck mo then compare the prices. Wag sa shops like Rapide! Hahaha mahal, ok lang dun mga tires. Banawe lang solve yan. Shopping capital ng mga auto parts hahaha
    paging PSG(power steering god) afrasay
    ako din, changed my power steering hose already best hydraulic hose pinalagay ko tapos check both ends ok pero may tumatagas pa rin, pero maskonti na lang. mga 1 tablespoon for 3 days yun tagas, dati hanggang ilalim. di ko alam kung saan nangagaling. di kaya nasobrahan lang ako sa fluid. malambot pa rin yun manibela, '94 big body corolla is my ride
    Quote Originally Posted by Chip View Post
    hehe...present :D
    Yun power steering pump ng patrol ko nga may tagas, need na palitan yun gasket...eh repair kit 1,200. Ok lang since di naman ganun kalakas ang tagas.
    Usually hmming sound during turning ang madidinig pag kulang or dirty ang fluid.
    Sep 2006
    Drain the fluid on low side(flush it) then fill it and bleed it(jack the front of the car so you can turn the wheel easily.
    Mar 2005
    Quote Originally Posted by afrasay View Post
    hehe...present :D
    Sir Afrasay, kung idi-drain ba ang fluid ay may kailangang fluid/additive na ginagamit na pang-flush ng pump at gears? Madumi kasi fluid ko at tuwing papalitan ng bagong fluid, dumudumi kaagad.
    You can just do a 'running flush on it'.
    Buy excess fluid, remove the return line (the one going back to the reservoir). As you fill the reservoir, turn the steering continously lock-to-lock, the old fluid should come out of the return line. Just catch it para hindi makalat. Kapag malinis na, pwede na ikabit ang return line.
    Just make sure you don't let the system go dry while you are doing this.
    Good day guys...
    ikutin eh.
    thank you po :D
    Try mo drain and replace the fluid. Bleed the system after doing this
Power Steering Problem
