Just bought new tires 31X10.5X15 (Yokohama Geolander A/T).
Nilagay na hangin don sa shop:
Rear : 35PSI , Front : 30 PSI
Ano ba dapat tire pressure sa mga A/T tires?
City Driving and Dirt Road Conditions?
yan ang U.S trooper specs for front/rear tyres. vehicle specific yan. remember to correct pressure when tyres are still cold. 30 psi all around ok din for my rig.
I have 30psi on all four 33x12.5x15.
It all depends on how your comfort level is, pag na titigasan kayo pagdaan sa mga lubak babaan nyo yung rear (~5). Pag sumbra naman ng lambot dagdagan nyo (~2).
SA akin 31-32 psi all fours. Yung increased pressure sa likod is for towing.
Up to 45 PSI daw kaya kaya ok lang 35psi eh takot ako baka sumabog nanaman to sa lubak pag sobra tigas...Originally posted by garyq
On another note...parang lumambot steering ko dito sa Yokohama compared doon sa Dunlop. Kahit mas malaki siya.
Because the Yoko's don't grip that much compared to soft compund Dunlops. Or you may have failed to notice the air pressure inside those tires when you compared both?
Yung Scarab powerboat ko hehehe
Hinde, i just noticed sa manuals na you have to put more air sa rear tires when you do tow.
Originally posted by mbt
pajerokid,
anong tinotow mo?
28-30 psi is a good ballpark. I only go above that when I'm towing (palay) or hauling stuff.
The sticker on my door jamb actually calls for 50 psi. Whatta stupid label.
fyi: normally pressure will increase by around 2 psi when the tyres are already hot. Measure tyre pressure when they are still cold or make the necessary adjustments when they are already hot![]()
Boss Ungas buti nalang di ako tinitigasan pag lubakOriginally posted by Ungas
:X sakit siguro non :X
