ano kaya best size ng gulong pag nag2-3" torsion and leaf spring lift?
With minimal modifications and cost cutting debates, 265/70R15 or 16 will do. That's almost the same size as 31x10.5R15 which is a more common tire size and different brands to offer.
Unless you are opting for bigger wheels such as 17s or 18s? Which you will need lower profile tires ranging from 55 series to 65 series sidewall.
16 nalang... sayang ang lift mo pag bling bling lang ang ilalagay.
parang maliit ang 70-15... 70-16 = nice. :D
235/75R15 po kasi ang stock ko. ok na siguro yun sinuggest ni sir ungas. Ano kaya maganda na brand na pasok sa budget balak ko kasi itrade in ang gulong ko bago pa naman ito? Salamat sa replies
Maliit ang wheel well ng Frontier. Check mo muna kung pasok ang 31" tires. Otherwise, 30x9.5R15 will work.
Kung sa Frontier ilalagay yan, a sure fit is 255 wide tread with 70 sidewall, para hindi sumabit sa fender and mud guards kung meron.
Baka kailangan mo pa ng additional lift either from body or suspension kung pipilitin mo mag 265.
according sa 2.5 inch lift by rancho and 3 inch lift ng calmini, 31" and recommended nilang size, tama si Otep, mdyo maliit wheel well ng frontier
Hmmm... 2.5" by Rancho & 3" by Calmini, eh di kasya nga ang 31's, tama ba trup?
quiksie::: 4WD po ba yung Frontier nyo? Paanong paraan na lift ba ang ginawa? Aftermarket springs and shocks or talyer TB cranking?
Naalala ko yung 4WD ni Phil G. na Frontier with 30mm OME lift, 255/75R16 ang nakakabit na goma mounted on Isuzu's OE rims 15x7.
sa frontier kailangan mong isagad ang TB in order to fit a 31x10.5x15 tires
i dont think your butt will agree on you on that.
my friend did this to his frontier, to his dismay binenta na lang niya ang frontier niya.
safe is the 30x9.5x15 or 255/70/15
kaya pala binenta ng friend ko ang 32x11.5 r15 nya na ikakabit nya dapat sa frontier. di pala kasya
andy
4x2 lang po ang frontier ko. same kami ng mags ng 4x4 pero hindi ko lang alam sa tire size. Ang alam ko ay mataas lang ng konti yun ride ng 4x4 sa akin kasi titanium edition yun sa akin mas mataas yun ride ko kesa sa ibang 4x2 ng frontier.
Sabi ng gagawa ng TB ko 2" lang ang kailangan icrank-up kasi harsh na ang ride pag 3" ang itataas. Dadagdagan nalang ng leafsprings yun likod para mas mataas pa din sa unahan.
Sige po try ko lahat ng possibilities. Tanung din ako sa mga bentahan ng gulong. Mabuhay ang tsikoteers!
quiksie,
max is the 2 inch pero wag mong isagad ng 2 gawin mong 1.5 also shave the bumpstop para may play pa rin.
thanks po sir kimpoy. Sana magkasya and wala maging problema ride ko
IF you need more lift, a body lift is your only other practical recourse.
A suspension lift on a 4x2 Frontier will only get you so far.
sir otep yun frontier ko halos kapantay na yun 4x4 kasi titanium edition siya hindi pa naadjust yun torsion. Antayin ko pa mavoid warranty sayang din kasi tsaka ko papalift. Wala ako budget na pang full bodylift eh. Mga magkano kaya pinakamura. Kasi nagcanvass ako torsion and leafspring(dagdag leaf-hindi pa kasali ang leafsprings mismo) adjustment is 2k
mura lang din naman ang body lift kaso maraming gagalawin at iaadjust, search mo topics about bodylift here.
pros and cons din.
