Results 21 to 40 of 45
  1. #21
    dexron 3 po ATFs ko--yun ang gamit din ng AT ng liteace ko,e... oh well, flush ko ko nalang--baka nakasama yung napahalong used ATF..
    nawawala ang foaming pag-mainit na...might buy a synthetic fluid, 2 liters lang naman,e...
    now ang pagbaklas ang problem--sikip ng van....
    #22
    Quote Originally Posted by banawe View Post
    your problem is sinugod mo sa baha
    well your problem is pag nabasa ang brakes usually umingay ito and malakas magkalawang yung mga rotor disc mo and caliper in your car
    for the noise you here while turning ... i think your problem is velocity joint ... meron kasing axle boot which covers your axle near your wheel ... pagbutas yun ... pumaposk yung water ... especially pag nululusong sa baha ... which causes your velocity joint to rust and break ...
    advice ... repack your axle or change you velocity joint ... buy a good king or grease to repack it ... not generic one ...
    BANAWE AUTO SUPPLY
    7120115
    regy
    i had no choice...emrgency kasi.
    ok thanks for your advice...i'll have it checked by a mechanic this weekend.
    just want to know how much will it cost me for a new velocity joint and repacking the axle???
    Apr 2006
    #23
    maraming powersteering fluid sa market ... castrol, STP, honda has its own powersteering ... basta usually powersteering fluid is malapot konti and whitish in color
    dun ka lang sa cold ... kasi ibig sabihin yan pag running yung car mo it reaches dun sa hot guage ...
    thanks regy!
    panu yan kung ATF na ang currently na nakafill up, pwede bang haluan ko agad ng PSF o dapat i-flush muna lahat?
    OT:
    nice meeting you sa phone kahapon. loko yun shop na nagsabing P1900 ang kyb shocks, out of stock pala!
    pero may nahanap padin ako natawaran ko pero mejo mataas na sa 1,900.
    next time sa 'yo na ko kukuha para walang hassle.
    ok tong si regy, matulungin at ok mag-advice!
    #24
    try nyo cyclo power steering fluid. yun akin nawala pati yun konting tagas
    Nov 2006
    #25
    tamang-tama yung pagka-bunot ng number ko sa GEB. me PSF na kasama
    dun sa loot bag. hehehe...
    ang tanong ko lang eh kung puwede kaya ito sa ESi ko? (sTp Power Steering)
    pang top-off ko lang.
    Jan 2003
    #26
    Is it ok to use locally made power steering hose? my return hose is already leaking.
    #27
    kung wala kang bugdet sir, pwede locally made hose. ako pinapalitan ko yun main hydraulic hose ng pang truck pero dapat pareho yun diameter nun hose na luma. nawala yun tagas kapag todo nakaliko. try nyo muna higpitan or use sealing products kung di ganun kalakas.
    Nov 2003
    #28
    local hoses tend to make noise/ugong pag niliko mo. i would go with the oem ones.
    May 2007
    #29
    pano po i flush yung ATF pra mapalitan ng PSF? or oks lang i mix nlang sila?
    Nov 2003
    #30
    ok lang pag emargency halo pero you should flush it after.
    #31
    kaya ba DIY flushing ng power steering? meron bang parang drain plug?
    May 2007
    #32
    yeah pwede ba yun? atf din nalagay ko sa kin, gago yung sa gasoline station ok lang daw yun. sayang ah! pinaayos ko kasi mounting ng engine ko then after a week or 2 npansin ko medyo mabigat or matigas steering ko, lalo na sa reverse or parking. isip ko bka sa fluid ky anapabili ako.. mali pa nailagay.
    Jan 2003
    #33
    update: i just purchased an OEM p/s return and a pair of local hose (small). the former was just a bended rubber hose. nothing special but the price. the latter was dirt cheap compared to OEM. 900 each compared to 130 a piece. DIY lang ang install nung small hose pero sa freelance p/s specialist ko pinakabit yung return hose. so far no leaks.
    Nov 2006
    #34
    hi guys, semi-off topic tanong ko.
    is it possible to install power steering in a vehicle, specifically sa minivan? if that's the case would you recommend any shop for installing such? thanks!
    Nov 2003
    #35
    if somewhere in the world that specific car came with power steering then just get those components and move it to your car.
    but if wala talaga then you will have to fabricate lots of the parts.
    Nov 2007
    #36
    Quote Originally Posted by macychic View Post
    naku, update lang po mga peeps, last night (less than 24 hours nun naglagay ako ng power steering oil) umingay na naman un steering wheel. i had it checked sa shell. then they told me na lumuwag daw un belt ng oto ko, kaya raw po bumibigay un hose, at kaya tumatagas agad ang nilalagay kong steering oil. or either nabasa un hose ng chemical na ginamit sa nun nagpaengine detailing ako (sa denjo, sa tabi ng Kilometer 2) hay, gastos na naman. palagi na lang akong malas sa shops :flush:
    I had a similar problem. What i did: i added Power steering fluid to the reservoir and at the same time turning the wheel fully over and over again. The noise eventually disappeared.
    Aug 2007
    #37
    question po. i have a honda city exi 97 model.. the power steering fluid is now at minimum level... i am not sure where to buy the power steering fluid. i read from some thread here that i cant use any ps fluid for honda as it could cause damage on ps tank. please help po. TIA ;)
    Aug 2010
    #38
    Sa akin di ko alam kung saan ang problem.. basta napansin ko lang di na ganun ung power nya o parang nawala.. kasi pagliliko medyo double effort na di gaya dati na onting turn lang ssunod na..
    Pero nung pinacheck ko sabi may problem na rin daw ung hose dapat palitan..
    Lagi ko naman check ung fluid parang di naman nababawasan..
    Ano po kaya talaga problem at solution?
    Thanks!
    #39
    Quote Originally Posted by ponglet View Post
    punta ka sa honda casa meron silang tinda doon about 600pesos 1 liter of psf, saan ba location mo, baka layo mo naman, meron din kasi sa las pinas piyeza meron silang tindang honda PSF
    Jul 2010
    #40
    Quote Originally Posted by rushmore View Post
    Thanks!
    baka nga maganit na mga hoses ng auto mo o sumikip na sa loob-parang ugat ng tao na me problema sa puso) kaya yung fluid ay di na makadaan ng mabuti.....fluid kasi nagtutulak para mas madali ang pagmaniobra mo.....
Power Steering
