Results 1 to 4 of 4
    May 2007
    hello,
    kakapalit ko lang ng gulong pag tanggal ng mags sinilip yung shocks sa harap kelangan daw palitan ng bearing. magkano ba yung bearing? kelangan daw palitan yung dalawa sa harap, P4.5k daw. ganun ba talaga presyo nun? san mura bumili ng bearing?
    tapos kelangan daw i adjust yung camber (tama ba spelling ko?) kano ba mag pa adjust? iba pa ba yung wheel allignment sa camber allignment(?)?
    sa makati ako so kung sakali sa evangelista ako papa ayos. may marerecomend ba kayo na shop dun na maayos kausap at tapat ang presyo?
    salamat sa mga mag reply
    Feb 2009
    Quote Originally Posted by eido View Post
    hello,
    eido,
    there are two bearings on each side of the front suspension. one is the strut mou t bearing found on top of the shock absorber tower which is visible when you open the hood or bonnet of the engine compartment, and the wheel bearings on the hub. both can affect camber of the front wheel
    the strut bearing which is insulated with neoprene or urethane are replaced in pairs since if you only replace one side, will give you handling surprises and might cause slight wandering of vehicle travel. the wheel bearing however, you can replace the side where it is worn out.
    jick
    May 2007
    *jick.cejoco thanks for the reply
    suspension arm bushing pala tawag dun. mag kano price nun?
    saka kano din mag pa camber adjust?
    thanks
    thanks
    what type of car do you have ... usually cost about 650 wheel brg for most cars
camber + front shock bearing
