Results 1 to 9 of 9
- May 2011
- 19
May 29th, 2011 03:41 PM #1ganito kasi ang nangyari.umiingay sya dati pag nag ppreno.
so check ko ung brake pads pudpud na pala.wala na.
then palit bago brake pads.ndi orig pinalit ko.800php lang ata un.
kasi nung pinalitan ko ung last un lang din pero wala syang noise.
eh nitong 2nd palit ko ng brake pads.nung una.walang ingay.
as in zero noise.tas nung medyo tumagal na pag gamit ko.umiingay
na sya.ano ba dapat gawin dito??linisin disc brake?ok naman disk brake ko e.
TYIA!
May 29th, 2011 04:06 PM #2
baka sa disk plate yan. kasi may ingay dun yun sakin dati eh. tapos pinalitan break pads+ disk plate. tapos oks na siya
May 29th, 2011 06:33 PM #3
brake rotors yung pinapalitan if manipis na. Same brand din ba ng brae pads and hindi pa pudpod?
- May 2011
- 19
May 29th, 2011 07:18 PM #4same brand.pero umiingay sya.dati naman hindi e.
before ko palitan hindi din sya maingay.
- May 2011
- 19
May 30th, 2011 03:55 PM #8
Pa-check nyo na rin brake calipers nyo. Most of the time sa calipers lang galing yang mga ingay when braking.
May 30th, 2011 08:25 PM #9
If you think about it, if the price of the battery does not go down, replacing the battery of a...
Mitsubishi Xforce
